What do I need to make rpf 1 18 x 10.5 +15 work?
I just got those sized rims didnt want to have to do anything but later reading people have been having to do modifications. I will be on swift racing springs and bilstein struts. Im on 18 w/ 255 tires and i scrape the liner on hard turns.
To make them fit and still have a useful suspension you need aftermarket body panels. The offset is too low for the rear of the car.
Yeah, +15 on a 10.5" is way too proud of the rear fender. Even those running the very popular Voltex over-fender dont run a +15 in the 10.5" IIRC
Steer clear of that spec :cool: Heres the layout vs what i run (note: my rears are fully worked!). This +15 would poke 1.09" further https://cimg9.ibsrv.net/gimg/www.evo...cf4df57f57.jpg |
Looks like im gonna have to swap em out for the 18 x 9.5 +15 .
The +15 is really not a great offset specifically in the rear of our cars. Must it be an RPF1? And are you opposed to running a spacer in the front? Im pretty sure they have a 18x9.5 +38 that would would pretty good but would most likely require around a 20mm spacer possibly a little less, I dont honestly remember bc I dont run RPF1s but I do know the info is posted here somewhere so please take a look or perhaps someone else in the fitment crew can chime in.
My main point was that I would recommend you pursue something with a higher offset. |
Eric, Pretty sure your notes the RPF1's are correct. If you dont run the +38, up front, you would have to run the +18 RPF1 & the +38 in the rear, but then you cant rotate
And, for sure, the +15 is not, in any width, good for the EvO rear. Some guys have certainly done it, but they rub & all the troubles that go w/it :crap: But, on the other side, if your going for the Stance fit-up, the +15 is OK. Not sure if youre a function > fit type or the other way around |
So stick with the stock fitment if i dont want any rubbing issues w/ also having springs
Originally Posted by Womb Raider
(Post 11843684)
You have to be willing to modify the rear fenders (rolling 3/4 or a full flat roll, fender pulling, bumper bolt relocation & a few other tricks may be needed) |
Which size requires the least mods?
No definite answer, but generally speaking IMO
17x9 to 17x9.5 +28 to +35 18x9 to 18x9.5 +28 to +35 Tire size certainly plays a factor You have to be willing to modify the rear fenders. No way around it! |
Mod rear fender in what way? Roll and Camber, just roll?
Not sure if Ive ever shared my ride w/you. Visually it looks very tame, in regards to wheel / tire fit but this set-up below required the following rear fender work
Now, imagine running that +15 which pokes 1" further than this. There is no amount of work that could be done to fit those +15's properly https://cimg2.ibsrv.net/gimg/www.evo...b0015a1ce8.jpg |
Hmm, very well. I guess i'll return these and get a smaller size.
Sending them back tomorrow. Does anyone else have any size inputs before I decide to task on a different size.
(Post 11844541)
Originally Posted by heel2toe
(Post 11843681)
Im pretty sure they have a 18x9.5 +38 that would would pretty good.
(Post 11843683)
(Post 11844089)
(Post 11844139)
Now, imagine running that +15 which pokes 1" further than this. There is no amount of work that could be done to fit those +15's properly |
