Lowest ride height
Hi guys,
I tried to do a search but could not any info. What is the lowest ride height CT9As can achieve without effecting the sensors(?). |
What sensors are you referring to?
(Post 11856924)
no. no sensors.
Originally Posted by McRooster
(Post 11856933)
Not too sure. I just read somewhere lowering the evo too much can affect a sensor. Maybe the speed sensor
For reference my ride height = Fender to ground = Front 25.375" & Rear 25.000" |
(Post 11857137)
Originally Posted by Nicolas
(Post 11857218)
is this the lowest you can get without problems?
No, theres more room to go lower but the sacrifice would be suspension performance. My front arms are already inverted (see pic) https://cimg0.ibsrv.net/gimg/www.evo...329cea31ad.jpg |
How low you can go and how low you should go are certainly two different things. MP posted a great picture of how quickly thing get bad. If you want to be low up front you're going to have a tri-podding monster because front and rear roll centers drop a much different rate (3:1 vs 1:1). Unless you fix the RC issues, but I doubt you're ready for that step.
On stock uprights, Id stick to around 26-26.5 ground to fender height (assuming OEM sized 25.3" wheel) up front and 1/2" lower in the rear. |
Thanks for the photo. so the arms must be aligned in order not to experience suspension sacrifice.
26 in front and 26.5 in rear are where the arms are aligned if i understand correctly |
(Post 11857393)
26 in front and 26.5 in rear are where the arms are aligned if i understand correctly As you can see, im not that low. Its really set up for track work. Any time you lower these EvOs (any amount) the front arms will go inverted to some degree Measure your EvO front & rear, fender to ground & let us know where it sits What Dallas was referring to with the heights is approx 26 to 26.5" at the front & rear should measure approx 1/2" lower due to the body lines. So the rear, could be 25.5" to 26" Thanks, Joe https://cimg9.ibsrv.net/gimg/www.evo...a1f1a5ec96.jpg |
Are you guys running 17 or 18 inch wheels? What is the ride height from the centre of hub to the guard?
(Post 11857585)
Im on 17's but running a 265/40 w/a tire circumference of 79" vs the stock circum of 76.5" |
