May Motor MAYhem! Short Blocks! 2.0L, 2.1L, 2.2L, 2.3L, 2.4L, 2.6L
Hey folks!
Another month has come and gone! Our machine shop is doing some awesome work! We've been building a bunch of great short blocks that have been going all over the world! No matter what kind of power you are making, we have a short block that is perfect for you! We work with the very best internal manufacturers in the world to offer you great short blocks! Check out some of the great short blocks that we have available for builds! http://sphotos.ak.fbcdn.net/hphotos-..._1609113_n.jpg SBR 2.0 Short Block (600hp): Our first level block is designed for anyone looking to build up to about 600hp. This is ideal for anyone with a stock frame turbo to about a 35R. They are built to rev and allow you to enjoy your setup. We build these with the OEM short block, OEM 88mm crank shaft and various rod and piston options. Our most popular 2.0/150mm Rod is: OEM Short Block OEM Crank Manley H Beam Pistons Manley Platinum Series Pistons (9:1) ACL Race Main Bearings ACL Race Rod Bearings ACL Thrust Washers SBR 2.0 Long Rod Short Block (600hp) - Check out this dyno on one of our long rod 2.0 builds! The long rod 2.0 is an awesome short block. The use of a longer rod with shorter,lighter pistons allows for greater revs! It's a very popular setup that can be classified as nothing short of, AWESOME! It is made up of; OEM Short Block OEM Crank Manley 156mm H Beam Rods Manley Platinum Series Custom Pistons ACL Race Main Bearings ACL Race Rod Bearings ACL Thrust Washers[/FONT][/FONT] |
2.4l 2.4l 2.4l 2.4l!!!!
Our 2.4 is one of the most popular on the planet! We've been building dozens of these a month and they are going all over the world!
Our 2.4 offers superior torque, spool up and longevity with quality parts and excellent machining and assembly. We can build a 2.4 to meet just about power, rev, performance and budget demand! With a lower core cost, we can offer the 2.4L at a lower price than the typical 2.0 or 2.3 while providing some GREAT performance. Check out just some of our most popular 2.4L builds! Check out our very popular, 2.4L! http://hphotos-snc3.fbcdn.net/hs456...._7078447_n.jpgWe've got several options when it comes to our 2.4! Here are just a few!!!! 1. 600hp Block -2.4L Block -Manley H Beam Rods -Manley 87mm Forged Pistons -ACL Thrust Bearings -ACL Main Bearings -ACL Rod Bearings -Machined -Balanced Rotating Assembly 2. 800hp Block -2.4L Block -Manley H Beam PLUS Rods -Manley 87mm Forged Pistons -ACL Thrust Bearings -ACL Race Main Bearings -ACL Race Rod Bearings -Machined -Balanced Rotating Assembly -Assembled 3. Big Power Block -2.4L Block -Manley I Beam Turbo Tuff Rods -Manley 87mm HD Forged Pistons -ACL Thrust Bearings -ACL Race Main Bearings -ACL Race Rod Bearings -Machined -Balanced Rotating Assembly -Assembled 4. Optimus Prime of 2.4L Blocks -2.4L Block -Manley Billet Crank Shaft -Manley I Beam Turbo Tuff Rods -Manley HD Forged Pistons -ACL Thrust Bearings -ACL Main Bearings -ACL Rod Bearings -Machined -Balanced Rotating Assembly -Assembled Here is a thread to the an EVO that Mojo/Ivey did with one of our 2.4L and you can see the torque and performance with the FP Black!!! http://i678.photobucket.com/albums/v...4lblackevo.jpg Check it out! |
http://sphotos.ak.fbcdn.net/hphotos-..._1791149_n.jpg
Our strokers have been in some monster EVO's! We use the quality parts, properly prepare the blocks and make sure that they will deliver everything that you need it too! We have TONS of options for our stroker! Here are just a few samples! SBR 2.3L Short Block (600hp) OEM Short Block Manley 100mm Forged Crankshaft Manley H Beam Rods Manley Stroker Pistons ACL Race Main Bearings ACL Race Rod Bearings ACL Thrust Washers Block Machining Block Clearancing SBR 2.3L Short Block (800) OEM Short Block Manley 100mm Forged Crankshaft Manley H Beam PLUS Rods Manley Stroker Pistons ACL Race Main Bearings ACL Race Rod Bearings ACL Thrust Washers Block Machining Block Clearancing |
Need a complete long block?
http://i678.photobucket.com/albums/v...s/IMG_7559.jpg
We build hundreds of long blocks a year! No matter what level you need it built too, Slowboy Racing has a long block solution for your EVO! |
Big Boy 2.6L!
I've had quite a few people ask about the BIG 2.6L, SO HERE IT IS!
http://sphotos.ak.fbcdn.net/hphotos-..._6683581_n.jpg Mitsu 2.4L Short Block Brian Crower 2.6L Stroker Kit -106mm Crank -BC Rods -CP Pistons ACL Rod Bearings ACL Main Bearings ACL Thrust Washers Block Clearancing Machining Assembly STARTING AT ONLY $3999!!!! BIG TORQUE! BIG DISPLACEMENT! |
http://hphotos-snc3.fbcdn.net/hs411...._6878176_n.jpg
If super man had a EVO, this would be his short block! This is a big power short block that will boost displacement, spool up and over all power handling ability! We're talking big time!!! SBR Super Stroker Manley 100mm Crankshaft Manley Turbo Tuff I Beam Rods Ross 2.3L Pistons Calico Rod Bearings Calico Main Bearings Calico Thrust Washer Decked Cleaned Machined Assembled |
holy mother of god........a 2.6L evo........can you say skyline killer
Originally Posted by kronik5383
(Post 8275897)
http://i678.photobucket.com/albums/v...ahle/mahle.gif
http://i678.photobucket.com/albums/v...ahlepiston.jpg The MAHLE PowerPak is a complete, race proven piston assembly kit composed of hand deburred, forged, performance coated pistons, high quality steel pins, round wire locks and low drag performance rings. Performance coatings include a phosphate dry lubricant that is used to protect against ring micro-welding and pin galling during initial startup and break in. For added performance, MAHLE applies its proprietary Grafal antifriction coating to each piston skirt. No matter what power level you are building too, we have a set of these light weight pistons, to meet your needs!!!!! |
Originally Posted by SBR INC
(Post 8275706)
any graphs with the 2.6l block?
machine shop has been keeping busy!!!!! Strokers, Long Rod 2.0 and 2.4L short blocks, all week long!
http://hphotos-snc3.fbcdn.net/hs485...._4358832_n.jpg http://hphotos-sjc1.fbcdn.net/hs485...._2628296_n.jpg |
What's happening TODAY at SBR? Good question, thank you for asking!
Picture of the motor build board! http://i678.photobucket.com/albums/v...p/IMG_0429.jpg Time to break int he dyno the right way! http://i678.photobucket.com/albums/v...p/IMG_0439.jpg Clutch job - RWD FTW! http://i678.photobucket.com/albums/v...p/IMG_0434.jpg Cores. http://i678.photobucket.com/albums/v...p/IMG_0432.jpg More cores. http://i678.photobucket.com/albums/v...p/IMG_0418.jpg Sorry, more cores. http://i678.photobucket.com/albums/v...p/IMG_0419.jpg Subaru heads heading to Barbados for a rally. http://i678.photobucket.com/albums/v...p/IMG_0420.jpg More of the rally prepped Subaru cylinder heads. http://i678.photobucket.com/albums/v...p/IMG_0399.jpg Tim getting ready to surface a Subaru cylinder head. http://i678.photobucket.com/albums/v...ngsubyhead.jpg I will post more tomorrow - I am back and ready to rock! Mike Huml Slowboy - |
busy busy day today in the machine shop! Couple of the DSM blocks got wrapped up and another EVO 2.4 in the works!!!!
