Are these numbers normal for my mods?
And for those who run 30psi on the OE turbos;
get ready to buy a new one in the next 20,000 miles as it wont bare that mechanical stress for too long.
I checked into it. my tuner said "SAE correction. Usually 18-20% depending on the conditions that day."
My dyno sheet reads "CF:SAE Smoothing:3
I don't know much about that, so chime in.
Either way car feels great, but ready for more!
I won't launch the car until funds for new clutch are secured, so drag strip is not on the horizon. I am sure DDing is killing the clutch allready. TRQ ftw.
The correction factor for 20psi of boost should be roughly half the SAE correction factor. I ran the calcs a little bit ago but I don't feel like doing them again. The correction factor depends on boost level.
Anyways, so with the SAE correction factor, it says ~360whp. So you actually put down about 300whp. Correcting to see level with half the correction factor of SAE puts you at roughly 330whp.
Never launch your EVO unless you have a spare transfer case laying around..if clutch holds & tires hook, stress is on the transfer case & axles..
OE turbo is small, it spools up really fast creating a lot of torque at low RPMs but it falls on its face after 6000. Boost drop is about 6-7psi, I tried to run a forge actuator and brought the drop to 4psi but it is still a dull turbo on top end. And thats what tells me its not efficient at high boost because it was designed for response, not top end.. I have quite a lot experience with a variety of turbos, trust me; before you try something new, the old setup always feels fast. This is the general rule
