15 X GSR GTX3076R Dyno results Whalen Tuned!
You can see my build thread here https://www.evolutionm.net/forums/pr...l#post11575834 , but this is the results of the build with an ATP GTX3076R on 93 and e85. I'm overall very pleased with the results and the great experience I had with John and the guys at Whalen's Speed R&D. He is definitely a perfectionist! We hit a limit on e85 because of the FIC 1100's, but we kept some room in the IDC % to stay safe on the stock engine. Here are the results!
How's the low end? Is this beefy enough to the point of not being able to be fully usable for canyon runs with back to back corners over and over again, as in it won't get a chance to spool fully
http://www.motoiq.com/MagazineArticl...-Cosworth.aspx
If you're worried about spool, can you also go with the smaller GTX3071R. There is also the smaller 0.73 A/R (vs. larger 0.94) if you really want better low-end.
I've usually kept it to about 7-7.5k rpm while making a quick acceleration or pull while I'm out driving it from point A to point B. It's solid advice though, I'll probably still shift just before 7800 rpm like you suggested for longevity sake.
The GTX3076R has been great, it's been very responsive in every situation that I've put it in so far. I'm in Illinois though so I couldn't speak much on making canyon runs, but going through some corners and twisty roads it's had plenty of get up for me and it doesn't seem to lag as bad as you may be thinking it does. As mentioned there is the GTX3071R option if you want slightly faster spool, however the few hundred rpm quicker spool up time wasn't worth the loss in power (and future potential power) for me. Good luck with whatever path you decide to take! Don't forget that I'm also on a bone stock engine and once the cams are changed and/or if the engine is built into a 2.2L/2.4L stroker it will help with the spool up time of the turbo.
FS[MidWest]: STM Staging Brake/Whalen Speed Booster Delete
Evo_AK
Jan 12, 2018 05:42 AM
06MREvo
47
May 16, 2017 06:40 AM
jnassar89
Apr 22, 2016 05:06 AM
Doug W
Jan 31, 2009 07:40 PM
