MAP Cast V-Band Turbo Kit - PTE5858
Old Nov 22, 2017, 12:07 PM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
If you get the 5862, I would go for the T4 twinscroll hotside. Otherwise the gen2 5558 looks promising.
Old Nov 22, 2017, 12:23 PM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
letsgetthisdone is right, I acquired this kit before the Gen 2 turbos where out.
If they where I probably would have gone with the 5558 Gen 2. If the Gen 2 5862 spools the same as my current 5858 I would get that but I have had a hard time finding much about the Gen 2's yet.
If I can't get my damn turbo to stop smoking I might go with a Gen 2 afterall...
Old Nov 22, 2017, 12:26 PM
Gen 2 only represents the new compressor wheel, the internals are the same. The turbo still smokes??
Old Nov 22, 2017, 12:39 PM
RazorLab's Avatar
Yes, not as bad but still smokes. I'm going to try and change the drain line fitting at the turbo to something bigger. The fitting MAP provided is 12mm and Precision recommends 20mm minimum on the inside, although I think they are now providing the "ported" version that I have ready to go on.
It's going to be a pain in the *** to change and it if it doesn't stop the smoking then obviously the turbo needs to come off.
Current:
New fitting to put on:
Old Nov 22, 2017, 01:04 PM
Kevin_White19's Avatar
From what I understand the gen 2 turbos have a broader power range. From what users and reps are saying a 5862 should spool like a 5858 and make more power. I haven't heard anyone dispute these claims although I'm skeptical myself. Coming from a EF4 I expect to see more pleasing results regardless.
Old Nov 24, 2017, 07:10 AM
ChipperEvo's Avatar
wow killer set up.
Old Jan 3, 2018, 05:20 PM
RazorLab's Avatar
Put the car on a real dyno today. This is a local Mustang dyno.
28.5psi flat across
14* max timing (8500rpm)
11.5-11.7 AFR
I'd turn it up more but I'm dropping fuel pressure 8,000 RPM +
Old Jan 4, 2018, 06:33 AM
eddogz's Avatar
Wow that looks amazing. Must be a beast when the power comes on.
Old Jan 5, 2018, 08:21 AM
ddlopresti's Avatar
Could you post a pic of the full dyno graph? i want to see the shape of it etc.
Old Jan 5, 2018, 09:26 AM
RazorLab's Avatar
Here you go:
ddlopresti (Jan 8, 2018)
Old Jan 5, 2018, 11:43 AM
six40's Avatar
That's a fair bit of power on that Magnaflow catback! Good to know
Old Jan 8, 2018, 07:11 AM
ddlopresti's Avatar
that's a pretty perfect graph. Must pull so hard towards redline, was this third gear?
Old Jan 8, 2018, 11:36 AM
RazorLab's Avatar
Yup, that was third gear. I was going to do a fourth as well but I was tight on time so I just did four pulls and unstrapped the car and left.
It did 544 with 26.5 psi (my first pull off the street)
Old Jan 8, 2018, 05:21 PM
ddlopresti's Avatar
that's great power for the boost. You think the higher compression helped that much?
Old Apr 20, 2018, 04:25 PM
whtrice's Avatar
Wonder what it would trap Bryan
selp
Jul 13, 2015 10:41 AM
ravnos04
Evo X Dyno Results
16
Feb 25, 2014 09:14 PM
RalliMark
Jan 8, 2014 03:10 PM
Levar
Sep 10, 2012 03:02 AM
EAVWIDL
For Sale - Cars For Sale
39
Jun 16, 2011 01:46 PM
Quick Reply: MAP Cast V-Band Turbo Kit - PTE5858
