Chris Robbins 35R spec turbo ••••
Yeah, and nearly impossible. I want to see what the turbine wheel looks like. I have a suspicion that Chris is using TD06H turbine wheels with 76R compressor wheels...which is not exactly revolutionary. BUT, I would be interested to see how many blades are on the turbine.
The turbines are 9 blade.
is it my spelling?
you sure are awefully quick to try and discredit someone Razorlab. Kind of makes me wonder...
for the record ][ The CR 35r spec turbo spools 1000 to 1200rpm sooner then the GTX 35r and cost approximately $800-1000 less.
100% Guaranteed Sorry but this is the best one I have. I started the pull much later (approx 3000rpm) then I usually do and you can still see how it hits 29psi just after 4K rpm
A stock frame turbo spools faster then a a T3 or vband setup? You don't say...
That looks identical to the ATP stock frame 3576.
This thing? Yeah...no. The snail doesn't impress me. I know what I am looking at, and I don't like what you got.
longevity aside, i'm a bit confused how this turbo can make 600WHP with less than 28lbs of boost. I'm not an expert really, just read on these forums alot and it seems this size turbo at that boost level is really punching above its weight. Am i missing something? If not, i'm very impressed.
Forgot I had this on my Ig page. This one shows a much better diagram of spool up. Same turbo same car with a bit less aggressive Ign Timing advance. I personally don't care much about dyno sheets or numbers. Only reason I wanted to post this is because of how impressed I was at how quickly these turbos can build boost Compared to the GTX 35r's. I'vehad the chance to work with a few of Chris's turbo's and they always out perform the competition, and as for claims that there's no way a 35r can spool like this.
Well, I'm not the only one that's used them and I'd bet that other people had the same results
Much Faster Spool
Able to reach the same power levels as the gtx
At almost half the price
Longevity has already been proven on at least two cars that routinely see High boost levels and lots of abuse. ( Currently 2 1/2 Years not one issue )
It's a badass turbo and I'd recommend it to anyone looking for a stock frame turbo
:u sflag:
Much Faster Spool
:u sflag:
So 3700rpm and the turbo is fully lit, but capable of 650whp with some real boost, like say 35psi or so? Since it made 600 at 28psi, making another 50hp with 7psi would be realistic. I have a very hard time believing that. For a turbo to spin up that fast you'll be sacrificing top end flow, not holding boost and power out the top. I'm all for more power, but I've been in the game a LONG time....and you can't have your spool and eat out the top on a 2.0 like that.
kpt6
12
Jun 2, 2015 07:18 PM
4g63girl
May 27, 2009 05:07 PM
