-   Evo X Dyno Results (https://www.evolutionm.net/forums/evo-x-dyno-results-298/)
-   -   Miguel's TTP-Tuned 5sp GSR- INJEN intake! (https://www.evolutionm.net/forums/evo-x-dyno-results/423249-miguels-ttp-tuned-5sp-gsr-injen-intake.html)
TTP Engineering May 26, 2009 01:38 PM
http://i4.photobucket.com/albums/y11...red_dyno-1.jpg
Miguel has had an interesting week jumping around from dyno to dyno in town here. After having his car tuned elsewhere with some ridiculous numbers 394/404 on pumpgas, he realized there was something wrong with the readings and took it to another dyno near his home where it dynoed in the low 300's.
Realizing that his car's power level was not what it appeared to be, he took down his dynosheets from evom in embarassment and gave us a call at TTP.
He contacted us for the retuning of his ECU and also to remove the manual boost control and move to ECU controlled boost.
The first thing we did was baseline the car as is where it put down 310whp on our dyno. Then we moved to swap out the MBC for the stock lines again so we could control the boost via the stock ECU.
In short time we had this completed and were on to overwriting the existing mapping and loading TTP custom MIVEC control, ECU controlled boost, fueling and ignition timing changes, boost limits, airflow mapping etc.
By the end of the tuning session, Miguel was able to remove his MBC and sell it, gained much power and tq over the baseline and no longer had the LIMP MODES all of the time with the previous reflash.
We do not want to get into a pissing match with the prior tuner so instead we have overlayed his last dynosheet with current mods and no tuning to our custom tuning with the same mods, less the removal of the MBC and using electronic ECU boost control.
Here are the results:
http://i4.photobucket.com/albums/y11...lay_miguel.jpg
Before:
http://i4.photobucket.com/albums/y11...JEN_MIGUEL.jpg
After:
http://i4.photobucket.com/albums/y11...guel_after.jpg
http://i4.photobucket.com/albums/y11...id/migred4.jpg
SHhhhh May 26, 2009 03:32 PM
Looks like you guys have been busy!
Ultimateone May 26, 2009 03:39 PM
Big difference to that other shop! lol
Good job
Clark_Kent May 26, 2009 06:44 PM
Looks nice, now lower that ride!
GGIXMRSE06 May 26, 2009 07:10 PM
Originally Posted by clark_kent (Post 7102121)
looks nice, now lower that ride!
^^ +1
newcomer81 May 26, 2009 07:25 PM
every single one of your posts on here are equally impressive. as always awesome job!
Shapdog May 26, 2009 08:36 PM
I guess ill be the second one in with that set up... save it!
compscibOi May 26, 2009 11:36 PM
Much better. Glad the customer was taken care of.
newcomer81 May 27, 2009 06:33 AM
if anything it goes to show how different dynos can be with the numbers. it is really all about the gains.
there was a 23% difference between 1 shop's dyno vs TTP's (yes i know there are additional factors). bump for a great job
Mad_SB May 27, 2009 08:32 AM
Why? so he can f up the roll centers...
How about:
"Now lower that bish and add a roll center correction kit" {thumbup}
To the OP.
Glad you got sorted out man, fwiw that "other" dyno was reading crank hp. I also noticed they never once mentioned whp, only hp so that kinda backs up my claim that they are calibrated to read crank HP not wheel and they know it.
Nice work TTP {thumbup}
EndlessRed May 27, 2009 10:40 AM
haha funny how cft never mentioned that their numbers are estimated from the crank, artifically inflating numbers to satisfy their customers. shameful.
but at least miguel doesn't have to be harassed about it anymore :lol:
nj1266 May 27, 2009 10:58 AM
All the owner had to do was do a baseline dyno on that other shop's dyno and then do a final dyno run on the same dyno and look at the GAINS. He could have saved himself a lot of money running around from dyno to dyno.
It is really tragic how people think that the numbers that a dyno spits out mean something. If the numbers on your dyno sheet are not compared to another dyno sheet from your car, then these numbers mean absolutely nothing.
Nevertheless, It is clear that this tune made gains over the previous tune from the other shop since TTP did it the right way by doing a baseline and then doing a final run after the tune.
nj1266 May 27, 2009 11:01 AM
Here we go again. The numbers do not matter, GAINS matter. The mistake that CFT did was not to baseline the car and simply provide the owner with a final dyno run. Had they posted a sheet with a baseline run and a final run, then we could see the gains. GAINS are what matters.
EndlessRed May 27, 2009 03:39 PM
still doesn't change the fact they gave inflated values without making their customers aware :rolleyes:
eagle claw May 27, 2009 04:18 PM
Good gain for sure, in the end the dyno is just a tool.
