LVSBB6's MR dyno
Got my MR tuned at a local dynapack facility, running stock turbo with bolt-ons listed in my sig, tuned via Cobb ATR on 94 oct. This dynapack reads relatively low compared to others, with around 50% drivetrain loss on AWD vehicles. As reference a 1.8T A4 makes 110whp and a V8 S4 makes 220whp on this dyno. While a stock STi only manages 190whp, I would imagine a stock Evo X would also make somewhere around this number.
The run-downs: Baseline: bolt-ons with no tune: 231whp/258wtq Green: bolt-ons with initial custom tune: 280whp/303wtq Blue: MIVEC tuning added: 276whp/298wtq (40wtq+ @3000rpm/60wtq+ @3300rpm) Pink: Okada plasma ignition installed: 279whp/301wtq (15whp+ @7000rpm) Red: Final tuned: 294whp/311wtq Boost: 23psi@3500rpm 26psi@4000-5500rpm 24.5psi@6000rpm 23psi@6500rpm 21psi@7000rpm A/F: 12.5 @ spool, 11.3-11.5 thereafter. Car is amusingly fast and pulls strong all the way, torque hits hard and and spool-up is insanely quick. SST is holding up well with the new founded power and shifts smoothly. I'm happy with the end result. http://i18.photobucket.com/albums/b1...X/Dynapack.jpg http://i18.photobucket.com/albums/b1...DynapackAF.jpg |
nice numbers man{thumbup}
well done as a fellow mr owner i am always interested in how your car is doing. glad to hear the sst is holding up
you really should get it re-dynoed at a proper dynojet facility. i never trust dynapacks, after all the inaccurate numbers i see it gives.
how are you hitting 26psi? what are you using to control boost?
Compared to dynojet, the dynapacks reads low especially this one, but it is a very accurate tuning tool indeed. I was getting consistent numbers run after run so I`m not sure how you come up with that statement. There is bound to be difference in numbers between dynos, and even within the same type of dynos.
Without variables of wheel pressure, alignment, strap tension and a built in weather station, i would say Dynapack is the most repeatable and is the reason why most big tuners and motorsport sanctioning bodies use them, and also why they cost twice as much. No one races dynos, they are simply a tuning device.
Originally Posted by endGameXIII
(Post 7377275)
Cobb AP and Jun wga.
Originally Posted by 617G
(Post 7377988)
was boost and/or timing increased in the final tune (red) over the blue/pink pulls? you seem to have some pretty significant gains between these. car must be a fun drive. can i try? :)
(Post 7377988)
Originally Posted by LVSBB6
(Post 7378062)
nice numbers
Boost is actually lower from 26.5psi to 26psi in the final run just to play safe, we made adjustments mainly on the timing and mivec tuning, A/F was tuned to be conservative in the low 11s. Its quite a blast to drive indeed :D
Originally Posted by nitz
(Post 7395434)
must be fun. take care of that tranny
| All times are GMT -7. The time now is 03:55 PM. |
