2011 Evo X GSR MHI 18K 402/354
1 Attachment(s)
Hey guys. Finally got around to installing the MHI 18k. TopSpeed Motorsports in Atlanta installed the 18K along with supporting mods. Car made 402/354 @ 26psi on 93 octane - Dynojet. Mods listed in signature. Dynosheet attached. YouTube video link of Evo attached.
I would like to thank everyone for their support and advice prior to my build. I'd also like to thank Mike at TopSpeed Motorsports for answering my 1000 questions, being extremely patient with me, and fulfilling all my requests. Any advice or input on my results is appreciated. :usflag: |
like your setup ! how to like the MHI turbo ? any lag for daily at low rpm?
Another awesome 18k thread. I want one so bad. Nice setup
Originally Posted by denlin68
(Post 11519249)
1 Attachment(s)
Ok so now I'm getting a check engine light, checked and it's a P0172 code via AccessPort. I did notice that the Evo blows blackish/charcoal smoke when in boost, but not really during highway cruising. Anyone know what could be the issue? Maybe a bad tune or too rich of a tune?
You may have a rich tune, please tell me you have a wideband and boost gauge. If you have a wideband this will quickly tell you if it's rich or lean--on 93 anything below 10.5 AFR after full boost is rich, anything above 11.5 is lean
I don't see anything about gauges in your sig. I believe you can log with AP but it won't have a wideband signal unless you added that. If you don't have a wideband, stop driving in boost until you install one or you're playing with fire--AEM, Innovate or Zeitronix are best. |
Originally Posted by lbcevo
(Post 11528309)
Liking the numbers on your setup! Let me know what you think about the Tanabe revel by the way (installation and overall rating). I can't decide between that and the AEM one.
Do a boost leak test. Sounds like you are leaking while under boost. Prolly a band did not get fully tight on the instal or maybe worked loose. Black smoke is also sign of rich mixture. But don't push the car hard in boost until you get the code or leaks resolved. Nice set up and tune btw. That turbo looks fun!
Originally Posted by Gan-san
(Post 11529015)
Originally Posted by ghozt
(Post 11529091)
Nice numbers. I just bought the turbo. I'm excited lol
(Post 11528309)
(Post 11529091)
What do you guys recommend? Note: MHI 18K on 93 octane, but I would like to go E85 in the future. I have a TSM 340 fuel pump (it's not hard wired, no fuel rail or FPR) Thanks in advance guys! |
If you plan to go E85 I would get the 1300s. It will give you a little room to grow and should max out right when that pump does.
- Robert |
I 2nd the 1300s if you can swing the extra cash. And might as well have them tune for e85 while you have it on the dyno?
yeah ID 1300 are normally 900, get them so you have room to mature like a caterpillar
