who's got a gtx3076 with S1 cams?
1 Attachment(s)
trying to find my 'potential numbers' for when i install my turbo next week and seeing if anyone has a similar set up
- GSR w/ GTX3076 ID1300 ets 3.5" with 3.5 housing full upper and lower piping 4" IC exedy stage 1 - DW65 right now might upgrade it before i retune i dunno if ill need to do the 320 for a dual map or not. gratzi people pic for attn: Attachment 270536 |
1 Attachment(s)
im guessing you're going to be on E85? you'll break at least 460 for sure!
I'd also like to know some information, I'm going with the ATP Garrett GTX3076R with full bolt on's, FIC 1100's and an AEM 320lph pump on e85. Stock engine and for some longevity a CC twin disk.
Originally Posted by BlueByU2004GSR
(Post 11571292)
- ran into an issue with advancing cam timing so trying to trouble shoot this still. Should pull like a train once it's all figured out, I have another thread with more details & trouble I ran into |
Originally Posted by Gtizks
(Post 11571469)
I made 380/340 low boost (23/24lbs)mustang dyno with tons of room to advance cam timing.
1 Attachment(s)
yeah after everything got sorted out it turned into this
Attachment 264298 still runs strong, not a single issue since getting everything sorted out |
- i had a 5 month issue with cam timing / mivec engaging which ended up being a bad bearing (.98cents) which i found out after replacing everything in my head haha.. 91 ****ty california octane.
- flex and 2.0 build sometime soon |
(Post 11665111)
http://i1175.photobucket.com/albums/...pshsenovqr.jpg still runs strong, not a single issue since getting everything sorted out Glad to know you sorted out all the issues. |
I have a gtx3071r and gsc s1 cams. Made 401whp 25psi 93oct at cbrds mustang dyno, so you should be upwards of that for sure.
| All times are GMT -7. The time now is 04:03 AM. |
