2015 Evo X GSR - MAP 5858 V-Band Turbo Kit
Finally made it to the dyno with my new setup after getting some misfire issues worked out. Managed to put down 425whp/326wtq at 25psi on 93 and 472whp/358wtq at 26psi on e85 (read e65 on ethanol gauge). Kept the maps conservative to keep my engine as safe as possible until I can build it. Looking forward to taking full advantage of my setup once my engine is strong enough. Pulls great and is a huge improvement over the Cobb staged kits that I was previously running. Tune is by Calvin Dotson at Dotson Tuning and dynoed at Evolution Dynamics in Lewisville, TX. Full mods list below.
https://cimg5.ibsrv.net/gimg/www.evo...c8e1301920.jpg https://cimg8.ibsrv.net/gimg/www.evo...1cdc2b3a46.jpg https://cimg9.ibsrv.net/gimg/www.evo...5855433bd0.jpg Performance: Cobb accessport TurboXS catback Cobb catted midpipe MAP recirculated v-band downpipe MAP 3.5 inch intake w/ K&N dry filter MAP UICP MAP LICP ETS 4 inch intercooler Turbosmart dual port BOV Grimmspeed 3 port EBCS MAP tubular cast v-band manifold Precision 5858 bb turbo .82 A/R Turbosmart compgate40 wastegate Walbro 400lph ID 1300cc Custom fuel line with filter and pressure gauge Driven Fab oil catch can/coolant reservoir Prosport Evo boost gauge Prosport Evo wideband AFR gauge Innovate ethanol content gauge kit WORKS short shifter AMS gate selector bushing Cosmetic/Interior: Redlined Coatings podercoated metal valve cover Driven Fab firewall heat shield Custom valve cover heat shield Custom modified engine cover 25mm spacers ARP wheel studs Muteki lug nuts Custom aluminum shift knob Android 10.2 inch head unit w/ reverse camera Depo HID headlight retrofit Diode Dynamics LED bulb replacements |
How does she drive? I bet that thing is an absolute blast on the street! Ps... thanks for the review! Over all, what do you think of the kit?
Originally Posted by maperformance
(Post 11708083)
Thanks so much for the feedback! It is much appreciated! I have actually personally run the 5858 and about a half dozen cars and always had good experiences. Nice little turbo that seems to hold up well to abuse, plus you have a bunch more on the table as they really start singing when you get em into the 30's heheehehe
Great to see more results. Can't wait to get mine all buttoned up. Running the 5858 .82 as well but will be on a sleeved 10:1 built 2.0L.
Thanks for sharing!. |
Keep up the great work! Looking forward to hearing about your experiences too!
Congrats on the new found power!
Originally Posted by razorlab
(Post 11708319)
Thanks for sharing!. probably get really close to 600hp? with being build and such and expected e85 |
A few questions...
One forum calls "full boost" - 20 PSI, what is considered spool? This kit seems like good power and safe because of later spool. But I'm concerned how much later is it? If I got this it would go onto a stock block engine, what is a safe rev limit in a pure street setting. I don't drag, do long "pulls", much less do track sessions. The center section is BB and air cooled? I thought water-cooled (edit) was standard these days or is there more to the story? |
Originally Posted by moparfan
(Post 11726330)
A few questions...
One forum calls "full boost" - 20 PSI, what is considered spool? This kit seems like good power and safe because of later spool. But I'm concerned how much later is it? If I got this it would go onto a stock block engine, what is a safe rev limit in a pure street setting. I don't drag, do long "pulls", much less do track sessions. The center section is BB and air cooled? I thought air cooled was standard these days or is there more to the story? It's not too much later, on the stock turbo I'd feel it begin building boost at about 3k. It's a little later but not unmanageable. A safe rev limit for the street would probably be stock, maximum 8k. Any more and you'll want to build the engine to do so safely. Yes, center section is air cooled, I had to loop the stock coolant lines together. Haven't had any issues with excessive heat yet. |
is the pte 5858 a bolt on turbo?|
Originally Posted by godlikelol
(Post 11726478)
Nice. Good price. Why did you stick the AP? Just curious. Calvin tuned mine when he was still at Cobb but I've since gone open.
Originally Posted by rico05
(Post 11726605)
1. I already had it so figured why not just stick with it 2. I knew I wanted to tune with Calvin and knew he worked with the ap often 3. I like the map switching 4. I like the built in code reader Once I get the engine built I'll probably switch it up. Looking to go flex fuel route in the future, so I'll see what my best option is that supports flex fuel but isn't too pricey to tune. |
Got ya. The AP is handy, but EvoScan can do much more than the AP as far as data logging and gauge display. You do have to haul around a laptop however. You can also map switch with open source. I did like having the gauges built right in, but after I switched I used the money from selling my AP and bout real AEM gauges.
Check out www.wtftuned.com for your flex tune. TJ is doing mine (I had a faulty flex sensor from another manufacturer). All he works on is Xs and 90% of what his shop does is flex fuel tunes. |
