2013 GSR 2.4L ATP GTX3576R 93 Octane Dyno
1 Attachment(s)
Finally finished her up! 503hp and 442tq on 93! She's a blast to drive! Can't do a E85 tune unless I do some fuel upgrades. With my current fuel setup I would have only gained around another 25hp before she would have maxed out on E85. Calvin at Dotson Tuning did a great job tuning her. MAPerformance did a nice job on the block and head.
Mods: AMS Downpipe AMS FMIC AMS LICP with Tial BOV AMS UICP ATP GTX3576R Stock location turbo COBB AP V3 COBB EBCS ETS HFC ETS V2 Exhaust GSC Behive Springs GSC S2 Cams ID1300 Injectors MAP 3.5" Intake MAP Stage 2 2.4L Shortblock (L.A. Sleeves, Wiseco 89mm pistons, MAP I beams, Manley Crank 9.2:1 Compression) MAP Stage 5 head +1 Valves MAP Fuel pump holder Radium fuel rail Uber Garage stainless cast manifold ported by GrimmSpeed Walbro 450 on factory harness |
Very nice! It looks like that stroker engine has you spooling so much earlier than I had expected. Sounds like a blast to drive! I wish I had that kind of time and money to put into mine :)
its pretty much keeping its boost nice man, are you feeling the turbo to be to laggy?
Originally Posted by godlikelol
(Post 11722956)
very nice numbers!
Awesome to see how early the 2.4L with S2 cams can spool with that kind of power on 93. I'm planning a very similar build and I would be very happy with those results.
That's a really solid powerband. 300tq over a 5k rpm range, more than half the engine rpm range.
nice numbers!
Sweet! Congrats, it must be a blast to drive now
Currently doing a build incredibly similar to that but I'm planning on going with a 6062 gen 2 bb turbo. How difficult would it be to get your setup to 600hp?
Originally Posted by Kevin_White19
(Post 11750615)
I may be able to get close to 600 out of it if I upgraded the fuel system more and ran E85. Realistically I think I would have to also look at running the upgraded GTX3582R Bolton on E85 or go big turbo and lose bottom end spool. |
The spool and power level is nice...
looks awsome
anyone seen a 2.4 like this with a 8374 efr?
I am actually building An identical build but I have the GTX 3582r.. same 2.4l from map I was just curious if your car is running great on that build thanks? |
