DVD Hack for the MMCS
On my dvd it says I have version 30.94 the UM one. But I used the 30.94 patch and all it does it check disk and then just disappears without doing anything.
Like i said before, i had the same issue, originally i used nero to burn it, and got the same checking disc issue, then i downloaded the ISO recorder to try it as a last ditch effort and it worked like a charm
What concerns me is that he says he has a Lancer GTS, which I thought had a different version of the NAV.
Also, try powering off the NAV and see if it's working in the background. I know someone on the other forum said that they had to turn it off and the prompt was behind the screen that was up.
I used the ISO recorder and it didn't work. I have the Lancer GTS, but a lot of people with the GTS used this patch and it worked for them.
Did my Evo X yesterday and my wife's Outlander today! Everything works fine and this will make those long trips much more enjoyable. I just sent the guy $10 and a huge thank you!!
You shouldn't have to unlock it. In fact, as soon as you put the drive back in it relocks it.
I think that either:
a) the burn is bad (from either bad/incompatible media or bad burner)
or
b) something is different about your unit.
Let's elimitate b) by you posting a picture of your versions info that you get by going to the "secret" menu (look in this thread, you hit two buttons).
or
