Where to Mount Mito 02 and Pac Swi Jack?
Hey guys, finishing up my install on my new head unit. Just wondering where you all mounted the MITO 02 and Pac Swi JaCk? I think it would be pretty ghetto to just shove it all back there. Is taping it to the chassis cross bar acceptable?
I haven't dug into my X dash yet, but in other cars I've used the industrial-strength velcro to attach small components with good results.
Used it to attach an Alpine SiriusXM module in an empty space behind the glove box, and I actually used it once to secure an amp and fiberglass sub box (which are both way too large for such an application imo).
Same idea as using double-sided 3M tape, but if you ever remove the component you're left w/velcro attached to the part and to the car instead of 3M residue.
Another good option would be using zip-ties if you can find a good spot, and use something as padding to keep any vibrations and noise to a minimum.
blonde
15
Oct 29, 2021 07:06 PM
Topdown
Aug 24, 2018 11:55 AM
Shrinkr
Jul 24, 2015 08:36 AM
cpunlamd
Apr 2, 2010 05:13 PM
