oem navi dash
I hate all the kits as well. They do have trim pieces, that you have to trim yourself, that allow you to keep the OEM piece. Problem is that the OEM radio is much larger than the double din units. The trim piece area will look large and out of place. Still better than the dash kits that out there though imo.
1 Post
Yes but the opening is slightly larger than double-din so you will need to ensure that you have a trim ring/bezel or you will have subtle but noticeable gap around your deck. The OEM NAV trim isn't ideal for an aftermarket deck. You will have to make a fair size custom bezel so it won't look very cohesive. Unfortunately due to the design and layout of the Lancer dash there isn't a 100% perfect kit for aftermarket decks. You just have to take a look at posted pics of various installs and choose the one you like best.
thanks for pointing it out.
now, whats the difference between jdm and usdm dash kit?
I think it depends on your model. The JDM kit is not bad but is pricey and I think you could order a USDM MR kit for probably not too much more.
I like my OEM piece. The first pic shows the hole you'll need to fill. My Clarion has the same size screen but is still smaller then most other decks so the gap effect is amplified. It used to seem really bad, but I'm used to it now. Plus I dig all of the functionality that the Clarion has.
You can get the JDM one at JapanParts. I'll see if I can find a part number for just the dash piece on the RF trim.
http://www.japanparts.com/db/parts_d...=&SEARCH_page=
bumping this because I also want the part# for the OEM navi dash kit (the wider one, not the one for aftermarket double dins). The one on the japanparts.com website (73165A) is not coming up for any US OEM distributors. Is the OEM wide navi dash kit only available in Japan?
