Wiring Questions for installing head unit
So im installing my AVIC HU but i am extremely confused on the wiring. i would like to think im pretty good electrically but after alot of research and wiring diagrams i cant seem to figure out how Mitsubishi set everything up. I have a 11 EVO X without RF sound system. i took out the factory head unit and there is 3 connectors. 1 connector was taped and didnt even go into the factory unit, the 2nd connector is an 18pin connector and the third is a 20pin connector. i dont know what the 18pin belongs to? the 20pin has 18 wires and i dont know where 5 wires belong. i know it sounds confusing but for some reason i cant upload a picture so Can someone please help me out or point me in the right direction? I appreciate it!
The other harness will have a multitude of wires; you want the red, yellow, and orange wires. The Evo X wiring is JDM colors, that means that the red and yellow are opposite of USDM wiring. Yellow is ACC 12v+ and red is constant 12v+. Orange is illumination wire. Black is ground.
If it were me, I'd just go to Best Buy and buy an adapter harness for $10
Yea, i bought a harness from crutchfield and i got most of the wires figured out but here is what i dont understand. On the 20 pin connector i am clueless to blue/black wire, white, orange, black/blue, and white/green. you said orange was for illumination but i got green/white wire for illumination.
Try not to over complicate your install too. You don't need every wire in the harness! You need power, ground, ACC, illumination, and speakers. Disregard everything else!
good luck
you're supposed to plug the crutchfield harnesses into those plugs and it converts the wire colors for you, and you don't need them all. If you got the proper harness, plug that into the white harnesses and then connect the matching colored wires to the new deck.
Got it. I left the damn parts in my shop so either later today i will get them or i will grab them tomorrow and start working on it. big help IKT. i will post pictures when i am done with the install. Thanks for the picture site. im new as you can tell..lol
Last edited by gonzo082; Aug 8, 2013 at 03:43 PM. Reason: forgot to write something
no problem, we all start somewhere right?
So i had two options. i have the metra mito-2 which i put in the radio. only the front speakers and tweeters work, and the sound is horrible. i also bought a crutchfield harness which i am now using and everything works like a champ. the only problem is now the info button does not work. i only connected the 20 pin harness connector. i dont know what to connect to the 18 pin harness?
For the "info" button, you probably disconnected it's little harness on accident. I've done it. Pop the bezel off and look behind the button and harness is probably not plugged in
MIT-02 is only for the factory Rockford Fosgate system, it also has a tendency to catch on fire.
Yea, i stuck with the harness i bought from crutchfield. The system is up and running. Thanks for the big help
[IMG]
[/IMG]
double check your tab on the top center there, you might have slipped below it when you clicked into place
[/IMG]
