Those of you who installed LED exterior lights, how did you pass through the wires?
I am on a mission to install some LED exterior lighting, Do i connect this setup to the battery in the trunk or do i just place the positive wiring under the hood and ground the negative to a bolt? How did you pass the wire from the trunk battery to the outside of the car without anyone noticing any wiring?
I am ordering lights and i am trying to figure out if i connect to the actual battery or to the positive terminal on the hood to make things easier?
If i connect to the battery where do most of you pass the wiring so i can place the lights on the exterior.
No need to flame me, I'm asking advice and im doing it anyway lol.
You could always just use a fuse tap to tap in into the fuse box which is already on the outside of the car. LED's don't draw much at all so I wouldn't worry about the current draw.
Also, if you wanted the LED's to turn on with the fogs or low beams, you can just use their fuse location.
LED smed bulbs for the exterior and under the car . The control box must be mounted inside the vehicle and I need to find a power source for it at the same time somehow getting the wires to the outside of the vehicle.
I could always pay a professional but I would rather learn myself on how to find a way to pass wires through the interior and exterior without notice for future reference.
In that case I would use a fuse tap on one of the fuses inside the car. Then feed the wires that need to go outside the car through the grommets on the left side of the footwell under the dash. Its actually a pretty convenient location. The control box can just be mounted under the dash somewhere next to the fuse box. There was a write-up on how to install gauges using these grommets so you can follow the instructions for your use.
https://www.evolutionm.net/forums/ev...lean-hell.html
The lights I have require a 12v power at all times. I'm not sure if the fuse box on the inside supplies that. I was going to wire the power directly front the battery or front the positive under the hood. That's why I asked for a location to pass wires through. Thank you also for the write up and advice guys.
Right. Use the Cigarette lighter fuse since it will give you 12v for as long as the car is turned on. If you use the battery directly or other constant source it will slowly drain your battery, which you don't want. Use a fuse tap and a fresh fuse for your LED lights. They typically don't draw much power so I don't think you'll need anything complicated like a relay setup.
AUTO Design
Vendor Classifieds
56
Sep 9, 2012 07:05 AM
zli05
Evo 'For Sale' Exterior Styling
62
Dec 11, 2007 03:03 PM
zli05
Lancer Ralliart Vendor Classifieds
Dec 2, 2007 08:34 PM
