Dw Hardwire kit help
Old Mar 21, 2019, 11:30 AM
gerikivan's Avatar
Recieved 4 Likes on 4 Posts
im trying to figure how to hardwire my walbro 450.. i know theres a guide for it but the old kit uses a different color wiring and never showed where to wire the 87. i pretty much figure everything except the yellow wire which i power to pump.. so where can i find the power to pump wire...
gerikivan is offline
Old Mar 22, 2019, 08:25 AM
Recieved 48 Likes on 44 Posts
You should really be running a new, larger gauge wire from pin 87 to the walbro to support the higher amperage. Check out this writeup:
https://www.evoxforums.com/forums/sh...ad.php?t=52658
splattj is offline
Old Mar 22, 2019, 09:41 AM
Biggiesacks's Avatar
Recieved 212 Likes on 202 Posts
the fatter wires are going to be your power and ground. My guess would be black is ground and blue is power. You can download the FSM for free from the evoscan website and it has all the circuit diagrams in it if you want to be sure. Or you can use a DMM to trace out the wires.
Biggiesacks is online now
Old Mar 24, 2019, 06:46 PM
gerikivan's Avatar
i traced the wire and i was wrong..the 87 (yellow wire) actually goes to the blue wire on the pump and now my new problem is does anyone know which one is the wire that triggers the fuel pump? yellow with red stripe wire or the white with black stripes wire?
Old Mar 29, 2019, 06:54 PM
gerikivan's Avatar
well i figured that the 86 and 87 goes to the same blue wire together
Old Mar 30, 2019, 12:23 PM
Recieved 23 Likes on 21 Posts
You lose the low/hi voltage feature of the ECU by doing this "hardwire mod". Depending on the upgraded fuel pump this can then overrun your stock FPR & return lines and cause erratic fueling at idle and out of boost conditions - FYI....
Jaraxle is offline
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
