Metra dash kit alpine unit in evo
put the metra dash kit in. i must say this kit fits very nice at least my kit. i installed an alpine ida-x001 for the ipod. the material of the dash kit is identical to the steering column on the evo. some gauges will be coming soon to take up the empty space. here is a pic.
http://i30.tinypic.com/2hxvrm1.jpg cant complain {thumbup} |
That looks awesome!
I really like that Alpine unit. Just wish it had a CD player. It isn't often I use CDs, but there is the occasional time... Does it work well? Seriously. Looks awesome. Look forward to seeing it completed with some gauges! |
Does you ride comes with the rockford fosgate amp? If yes how do u link it up with ur Alpine Headunit
That looks good, thanks for posting a pic.
looking good, alpine is awesome
What are the size of the gauges that you are going to put in below your HU? Do you think 3x60mm DEFI can fit in a single din space with a little cutomisation? Thanks!
that gap at the bottom of the metra kit bugs me. I wish they'd fix that!
where did you get that dask kit from? or is it from the old stereo?
That looks pretty clean bro! I've had Alpine decks in the past and have nothing to complain about them. :thumbup:
Originally Posted by dunstop
(Post 5418689)
Think this might help some of you guys NAV Unit: ***These wires are low voltage outputs for the amp*** Front Left Speaker + WHITE Front Left Speaker - BLACK Front Right Speaker + RED Front Right Speaker - GREEN Amplifier under Driver Seat: Battery Positive + RED (pins 25, 35, 36) Ground - BLACK (pins 24, 31, 32) Front Left Speaker + White/Blue pin 28 Front Left Speaker - Black/Yellow pin 38 Front Left Tweeter + White/Blue pin 6 Front Left Tweeter - Black/Yellow pin 14 Front Right Speaker + White/Red pin 27 Front Right Speaker - Black/Red pin 37 Front Right Tweeter + White/Red pin 5 Front Right Tweeter - Black/Red pin 13 Rear Left Speaker + Yellow/Blue pin 1 Rear Left Speaker - Gray/Blue pin 7 Rear Right Speaker + Yellow/Red pin 2 Rear Right Speaker - Gray/Red pin 8 Subwoofer coil #1 + Gray Subwoofer coil #1 - Yellow Subwoofer coil #2 + Blue Subwoofer coil #2 - White |
nice install {thumbup} I'm looking to do the same in a few days ..
Originally Posted by thuan
(Post 5433402)
I took this from "PDXevo"
Think this might help some of you guys NAV Unit: ***These wires are low voltage outputs for the amp*** Front Left Speaker + WHITE Front Left Speaker - BLACK Front Right Speaker + RED Front Right Speaker - GREEN Amplifier under Driver Seat: Battery Positive + RED (pins 25, 35, 36) Ground - BLACK (pins 24, 31, 32) Front Left Speaker + White/Blue Front Left Speaker - Black/Yellow Front Left Tweeter + White/Blue Front Left Tweeter - Black/Yellow Front Right Speaker + White/Red Front Right Speaker - Black/Red Front Right Tweeter + White/Red Front Right Tweeter - Black/Red Rear Left Speaker + Yellow/Blue Rear Left Speaker - Gray/Blue Front Left Tweeter + White/Blue Front Left Tweeter - Black/Yellow Subwoofer coil #1 + Gray Subwoofer coil #1 - Yellow Subwoofer coil #2 + Blue Subwoofer coil #2 - White I think he forgot rear right, but im sure you guys can figure this out. Maybe just let you know my problem. I've purchased a JVC HeadUnit - AVX805. The installer says that he has problems wiring up the headunit to the amplifier. So wat he did in the meantime is that now he wire the 4 speakers direct to the HeadUnit...bypassing the amplifier. It means that he has actually found the individual 4 speaker wires out from the stock headunit. I suspect that I'll just need to wire the 4 speaker wires to the JVC Headunit...but he say cannot work coz need other wiring. So I'm not sure also. Any help will be appreciated. |
like the setup, just wondering if this kit is available in Toronto. Seems only online
That is probably one of the better installs i have seen on here with a metra kit. It seems everywhere I look on here people are complaining about it, which worries me a little. My Double Din JVC nav system gets installed tomorrow, Im just waiting for the metra part to arrive. That is a sweet alpine HU though. I love The ipod Control on it!
Here is my Metra Kit with a Pioneer P4100DVD. It is also a carbon fiber look.
http://i117.photobucket.com/albums/o...dy81/002-1.jpg |
