Rockford Amp replacement
For those that swap the Rockford amp for another amp, were you guys able to maintain Fade and Sub control?
Any work arounds? Thanks |
You can keep fade control assuming you're using a 4-channel or 5-channel amp and have it connected correctly.
Nobody has been able to figure out a way to keep the sub control (Punch level). |
The OEM Nav only have outputs to the front speakers and no output to the rear. How will the amp fade?
Originally Posted by malymabl97
(Post 7807721)
Originally Posted by Webman
(Post 7808964)
Are you sure about that? That wasn't my understanding. I know you can lose the bass adjustment, but I thought the deck put out all 4 channels.
that scks, i use the Punch adjustment more then anything else
Originally Posted by mmartahus
(Post 7809196)
https://www.evolutionm.net/forums/ev...d-oem-amp.html
In the link they say you lose fade. Looking at the wiring, it does not have a rear out. |
I'm a noob at car audio, and I'm not sure if the following setup will work.
Stock amp output -> after market amp -> speakers. This should keep all functionality. |
I stand corrected on the fade capability :D
(Post 7809271)
(Post 7809271)
(Post 7807680)
Any work arounds? Thanks I've already did what you are attempting to do with great results!! |
I'm not sure about the standard head unit but the Rockford Unit only has 2 outputs (low level). The fading and sub control are operated by the canbus.
(Post 7809271)
This should keep all functionality. Don't worry about losing the sub control at the head unit. 1) it sucks because it mutes the output when you adjust it. 2) it also doesn't allow you to fine tune the x-over freq. I do not miss the factory sub control at all. Oh yeah... with my setup I can fade, left/right and complete sub control. |
