oem navi dash
the after market dash kits all look cheap imo.
what does it take for you to use the oem navi dash kit with after market doub din navi? |
Originally Posted by ImEv0
(Post 8239322)
Get the JDM double din unit, same quality as OEM.
Originally Posted by Jwilliams
(Post 8240227)
(Post 8242094)
and the jdm dash kit will work with after market double din?
Originally Posted by heavyD
(Post 8242429)
Yes but the opening is slightly larger than double-din so you will need to ensure that you have a trim ring/bezel or you will have subtle but noticeable gap around your deck. The OEM NAV trim isn't ideal for an aftermarket deck. You will have to make a fair size custom bezel so it won't look very cohesive. Unfortunately due to the design and layout of the Lancer dash there isn't a 100% perfect kit for aftermarket decks. You just have to take a look at posted pics of various installs and choose the one you like best.
thanks for pointing it out. now, whats the difference between jdm and usdm dash kit? |
(Post 8242578)
I like my OEM piece. The first pic shows the hole you'll need to fill. My Clarion has the same size screen but is still smaller then most other decks so the gap effect is amplified. It used to seem really bad, but I'm used to it now. Plus I dig all of the functionality that the Clarion has. http://i208.photobucket.com/albums/b...l/100_0166.jpg http://i208.photobucket.com/albums/b...l/100_0241.jpg |
ic...
that looks great! |
The JDM comes in two trims, one for stock navi with wider opening and one for aftermarket double dins that has a trim piece to fill the gap.
Does anyone have the part# for the stock navi bezel (rocker fosgate), or know where I can get the JDM double din bezel? Thanks!
You can get the JDM one at JapanParts. I'll see if I can find a part number for just the dash piece on the RF trim.
http://www.japanparts.com/db/parts_d...=&SEARCH_page= |
Originally Posted by mrMTB
(Post 9909254)
bumping this because I also want the part# for the OEM navi dash kit (the wider one, not the one for aftermarket double dins). The one on the japanparts.com website (73165A) is not coming up for any US OEM distributors. Is the OEM wide navi dash kit only available in Japan?
^^ The OEM wide should be available in the US - if it's available separately from the entire RF Navi install kit.
PM RussellM.. he should be able to tell ya. |
Originally Posted by Jblade
(Post 9971603)
