-   Evo X Electrical / Audio / Security (https://www.evolutionm.net/forums/evo-x-electrical-audio-security-262/)
-   -   Weird Problem with Driver's Side Taillight Bulb (Not Brake Light) (https://www.evolutionm.net/forums/evo-x-electrical-audio-security/699364-weird-problem-drivers-side-taillight-bulb-not-brake-light.html)
alby988 Sep 12, 2014 03:03 PM
Hey guys, I'm having a weird problem with the rear tail light. The light that comes on when we turn our lights on (not the brake light) doesn't go on once in a while (driver's side only).
Out of frustration, I did a light tap on the tail light that went out and it came back on. Ever since then, whenever I notice the light isn't on, I just tap the outside and it comes back on. :confused:
Does anyone have an idea of what may be wrong and what steps I should take to fix it?
I'm guessing it's not the bulb as the light comes back on when I tap it, is it something with the connection? And if so, what should I check for?
Thank you guys, really appreciate it! :helpme:
Edit---
Changed the wire and viola works perfectly now :D
.M. Sep 18, 2014 07:47 PM
Check the connection/wires like you said. Make sure nothing is loose. The bulb might not be making good contact. You can always change it if you're not sure. I'd start with that.
