Evo x radio and fob not working after battery change
Recently changed my battery on my Evo x and the key fob won't work to remotely lock and unlock doors and the radio also won't work..any help would be appreciated..I can't imagine that the fob needs a dealership to sync seeing as a battery can fail any time...tried to sync the fob as recommended in the manual but no good.
thanks guys |
You could have blown a fuse(s) if the battery arc-ed. Take a look-see under the dash and see if anything popped.
Thanks for that jakgal04 I'll check it out when I get back from shift...any thoughts on the key fob?
Originally Posted by nzmade1988
(Post 11777689)
Thanks again Jak, I'll have a crack at it on days off and get back to you.
The fuse looks in perfect condition but I'll pick up a new one just in case. Anyone else have an idea about the fob not locking or unlocking the system?
in my wife car every single time when you disconnect battery you have to program key, Idk just my guess
both of my key fobs (not fast key) decided not to work all of a sudden.
Tried the steps in the manual to reprogram them but nothing. Going to schedule a time with dealership (I hate going there...) to see if it can be reprogrammed. Any idea why both fobs would just lose communication with the car? |
I have same issue now with my evo x after changing battery, any solution? Fuses all good
Fob, radio, aircon, side mirror fold not working |
[QUOTE=3zero7;11899355]I have same issue now with my evo x after changing battery, any solution? Fuses all good
Fob, radio, aircon, side mirror fold not working I got the same problem. Radio dome light dont work and keyless fob dont work , all fuse are good. |
