Anyone with Android 7.0 or 7.1?
Looking to see if anyone has this head unit yet? Any problems with it? Are you satisfied with it? Any add ons that are necessary?
Originally Posted by UH-60Driver
(Post 11790531)
Yes, I recently got a used Evo X with 56K km and I installed the new Nougat 7.1 Head Unit from Sygav. So far it is working perfectly, had no problems with it whatsoever. The only thing I would comment on is that some times you need to manually connect your phone with the BT, but my phone might be at fault here so I can't 100% blame it on the HU. I've installed several apps on it, running perfectly until now...the only thing I'm looking to fix is the TPMS and what should I get in order to get it to work. So, highly recommended. When I find some time I'll do a video on it and make sure to post it here as well. |
Will the steering wheel controls still work with these android head units?
I put the quad-core Sygav in my Wife's RA over the weekend. Everything, including the steering wheel controls, works perfectly with her Rockford Fostgate equipped car.
The quad-core running on 7.0 is a little slow (uninstalling/installing apps took a minute) but once running has been really good! |
(Post 11790531)
Yes the steering wheel buttons will work, as long as you select the right one, there is a different model between 2014-2015 evos and 2008-2013 as well as if you have the factory rockford fosgate amp. Just make sure you do your research and it will work!
If you guys have any more questions about this unit feel free to ask!
