Hks Camp 2
Old Jul 1, 2008 | 06:12 PM
  #31
gunzo's Avatar
That's not a mitsu NAVI unit .. it's an Alpine unit
I can select video source on screen and audio source from another input ..
I put the Nav warning on so that if I reach a turn point .. the Nav unit will flash onscreen for about 5 sec before going back to the CAMP2
Old Jul 1, 2008 | 06:35 PM
  #32
Xcited's Avatar
"buy the HKS Knock / AF amp and plug it in ..
So the answer is YES again"
Your wrong.
The answer is NO. You won't be able to output the AF data through HKS camp 2 buy just plugging in the Knock/AF Amp. You need to have an F-con unit which is $1300.00. You can only use an I/F unit which has the capability to output EGT not AFR.
This is why I'm using the R-vit DS by Blitz.
Old Jul 1, 2008 | 09:03 PM
  #33
Sa7aN's Avatar
im just gonna get the new trust touch informeter
Old Jul 2, 2008 | 03:49 AM
  #34
gunzo's Avatar
Your wrong.
YOU are wrong
The instruction booklet actually tells you how its done ..
Oh yes .. sorry .. you don't have a CAMP2 ..
I've compared both the CAMP2 and the Blitz unit .. For now, the Blitz does not allow you to monitor anything else other than what is through the OBD port .. whereas the CAMP2 allows you the standard monitoring sensor attachments via the I/F .. and AMP .. and Vpro or SZ
Chill Bro
Old Jul 2, 2008 | 06:17 PM
  #35
Xcited's Avatar
YOU are wrong
Chill Bro
Man, you are a fountain of useless information.
The Blitz unit does more than just read the OBD 2 port, do some research, Oh yes .. sorry .. you don't have a Blitz R-Vit DS....
Before you mislead everyone else with your posts you had better read your manual for HKS camp2 because clearly you have know idea what you are talking about. Like I said, you can't just buy the AF unit and plug it in, YOU ARE WRONG.
Old Jul 2, 2008 | 07:17 PM
  #36
gunzo's Avatar
Oh yea .. you're good .. you're worse than a mountain of useless info then .. even when you HAVE the blitz unit .. jeez ..
http://www.blitz.co.jp/products/elec...s/r-vit_ds.htm
Go read this .. oh yes .. you do have it eh ?
You only have 3 ..read 3 other sensor readouts .. 1 TEMPERATURE and 1 PRESSURE and 1 optional A/F .. oh yes .. you do know you need to get the data translater unit for the 3 extras right ?? not just a plug in the sensor and play ???
Wow .. I don't even want to compare your comprehension on this ..
and YES I WENT THROUGH THE MANUAL .. AND YES IT SAID YOU CAN ..
You can go read your HKS INSTALL manual to confirm then ..
Old Jul 3, 2008 | 12:57 PM
  #37
Xcited's Avatar
You are not smarter than a fifth grader. Enough said.
Old Jul 3, 2008 | 05:00 PM
  #38
gunzo's Avatar
\/\/hatever dude .. I spell better than you so does that make you worse than a 5th grader ???
I don't even know why you're arguing about this since you already have a Blitz .. maybe its a "I KNOW MORE THAN THOU" or a weener issue ?????
Old Jul 3, 2008 | 10:12 PM
  #39
THE JAVI's Avatar
HAHAHAHA....you said weener.
Old Jul 4, 2008 | 12:51 AM
  #40
Mojito's Avatar
I second that. A/F kit doens't directly plug into Camp2, not even through the sensor inerface (forgot what it's called). You need F-Con. I wish it did though, then I would jump on Camp2 without doubts. But without A/F it's not that useful.
Old Jul 31, 2008 | 11:43 AM
  #41
tomatoEVO's Avatar
i might get camp2 if it's compatible with my mmcs navi. looks great
Old Jul 31, 2008 | 12:04 PM
  #42
PaRanHaNeul's Avatar
will it run while playing music as background?
SmurfZilla
Aug 16, 2015 03:50 PM
hiner005
12
Jun 28, 2014 11:32 AM
kpt6
Mar 21, 2014 05:12 PM
rcantu
Mar 15, 2014 12:23 AM
