ACD error after ECUflash
Old Feb 3, 2009 | 06:04 AM
burnings's Avatar
Hi,
Anyone encountered ACD errors after ECUFlash? The car did not throw any CEL or watsoever but upon reading error code from my scanner, there are a series of ACD error codes.
Old Feb 3, 2009 | 06:14 AM
wickedchimp's Avatar
I haven't run into any errors at all. I have a usdm ecu though. Sic might be able to help you out. I think he is the jdm beta tester.
Old Feb 3, 2009 | 10:54 AM
GST Motorsports's Avatar
Originally Posted by burnings
Hi,
If you have a MR with SST you need to "exit programming mode" and also "clear DTC's" after flashing.
Old Feb 3, 2009 | 12:08 PM
burnings's Avatar
Mine's a GSR 5MT...
Old Feb 3, 2009 | 01:47 PM
Mine's a GSR 5MT...
Did you "Exit programming mode" after flashing?
Are the errors coming up as soon as you start the car or?
Old Feb 3, 2009 | 01:51 PM
burnings's Avatar
Nope.. I did not Exit Programming Mode after flashing and I don't know when the error comes up as there are no CEL or watsoever. It just appears when I tried to read error codes after test drive.
Old Feb 3, 2009 | 07:18 PM
Then that is why, you need to exit programming mode after flashing.
Old Feb 3, 2009 | 09:43 PM
gunzo's Avatar
There is no requirment to exit programming mode
If he's in programming mode he can't start the car ..
johentie
Apr 5, 2013 07:11 AM
fireroasted
Dec 15, 2011 02:24 PM
Toxin
18
Mar 28, 2010 07:40 PM
GiGas
Oct 1, 2009 02:27 PM
2JZfan
Mar 20, 2007 03:33 PM
