evoscan
Old Apr 10, 2009 | 07:19 AM
  #31
FX11's Avatar
o i just want the OP2.0 to datalog already!
Old Apr 13, 2009 | 08:29 PM
  #32
bbarnhill's Avatar
is anyone else turning blue from holding your breath?
Old Apr 13, 2009 | 08:31 PM
  #33
jmorris1027's Avatar
its out already.
https://www.evolutionm.net/forums/ec...en-review.html
Old Apr 14, 2009 | 06:55 AM
  #34
KGHtheII's Avatar
Originally Posted by jmorris1027
Not exactly. Its in early beta stages. Not even all of the default functions are working properly yet. Its going to be a little while longer.
Old Apr 14, 2009 | 11:14 AM
  #35
its better then nothing.
Old Apr 14, 2009 | 11:38 AM
  #36
boostin20's Avatar
+1, still good news. At least we know actual progress is being made.
Old Apr 14, 2009 | 12:33 PM
  #37
Red Dragon's Avatar
Can wait till the real version comes out!
I would like them to make a box that can connect to external gauges such as boost, wide band 02 sensor, oil temps, trans temp, egt, etc... and have the box connected to the Evoscan touch screen via USB port so you can view them on the screen.
Old Apr 14, 2009 | 01:02 PM
  #38
criptballer's Avatar
it has an option to logg external wideband doesn't it? anybody know if it can logg knock properly? i saw that there's a PID you can select but i dont know if it actually works.
Old Apr 14, 2009 | 01:42 PM
  #39
There is a pid for knock-retard but it didn't seem to work for me, and load maxed out at 255. And when we tried to raise the limit, evoscan wouldn't connect to the vehicle. =[ oh well. I'm sure they'll figure it out.
Old Apr 14, 2009 | 02:48 PM
  #40
Guru's Avatar
damn getting close though.
Old Apr 15, 2009 | 07:47 AM
  #41
missionstatemen's Avatar
any one with a serial connector can tap into the aem wide band
Old Apr 15, 2009 | 08:57 AM
  #42
rogue's Avatar
How can we connect and external boost source, such as my AEM unit (it has an output for it).
Old Apr 21, 2009 | 08:13 AM
  #43
pltek's Avatar
just bumpin for update
Old Apr 21, 2009 | 11:30 AM
  #44
You have to connect the blue wire from the aem wideband to pin 2 of a serial connector and ground one other wire or something to that effect. It tells you on the directions.
Old Apr 21, 2009 | 12:47 PM
  #45
WarmAndSCSI's Avatar
Same here.
Not getting much useful info from EvoScan right now, but it works.
Also, I am having problems in 64-bit Vista involving a missing DLL when I try to connect. I've been using EcuFlash so I know the OpenPort 2.0 drivers are installed. I had to reboot into XP, and EvoScan works there.
I'm going to try some dyno pulls this evening. Maybe the greater resolution from the CAN connection will get us some nice looking road dyno graphs! I'll try exporting to DataLogLab as well.
