Will EvoScan monitor fuel pressure?
Old Sep 9, 2009, 10:59 AM
Tractionlimit's Avatar
Is there any reason to log fuel pressure, or do people just do an analog gauge for this? I have an inline pump and want to make sure I know if it fails.
Old Sep 9, 2009, 11:04 AM
rfielder's Avatar
EvoScan will not monitor fuel pressure as there is no fuel pressure sensor in the car. I would only monitor fuel pressure if I started to have a lean running condition.
Old Sep 9, 2009, 01:11 PM
Yeah, I meant with an external sensor. I guess this answers my question though. I currently am seeing a lean condition, and am trying to decide what to purchase. It sounds like a classic analog fuel pressure gauge is the way to go instead of trying to monitor it continuously.
Old Sep 9, 2009, 02:56 PM
rfielder's Avatar
You may check this thread:
https://www.evolutionm.net/forums/ev...under-wot.html
Or this one:
https://www.evolutionm.net/forums/ev...ur-engine.html
Not sure if that is what you are experiencing, but I have seen this before.
Old Sep 10, 2009, 09:03 PM
mrfred's Avatar
If tephra has identified an unused ADC input (both physical location and location in ROM code), then it would be relatively easy to wire up a pressure sensor. I did this on my Evo 9.
Old Sep 11, 2009, 05:51 AM
Thanks, this is what I'm looking for. I'm running an external inline fuel pump, and would like a failsafe to monitor its operation at all boost levels. I've considered an analog gauge, but I'd like to have something log-able.
Tephra- if you're reading this, do you forsee this as a future option for us?
Thanks.
Old Sep 14, 2009, 10:20 PM
Thanks.
What is the best way to contact Tephra? He doesn't check PMs, right?
Old Sep 14, 2009, 11:29 PM
tephra's Avatar
Traction - Got your PM
1) as mentioned already EvoScan can ONLY log whatever sensors the ECU currently has access to
2) fuel pressure is NOT available to the stock ECU
3) You CAN connect additional sensors - they need to output a 0v to 5v range, preferably linear although its upto you and EvoScan to convert voltage into something meaninful
We have identified a number of FREE ADC inputs (ADC = Analogue to Digital Converter, x voltage into a number) on CT9A however I havn't looked properly for CZ4A.
I will be doing this as part of my altmap setup for CZ4A (for my Meth failsafe) so stay tuned.
Cheers
David
Old Jan 15, 2010, 07:51 AM
tsitalon1's Avatar
Tephra,
I think you know why I'm all of a sudden interested in this
Has this effort gone anywhere?
Jovan Caro
Feb 6, 2017 08:03 PM
mrfred
E85 / Ethanol
29
Dec 10, 2008 08:46 PM
LT1runner
15
Jan 14, 2008 10:10 AM
rt turbo
Nov 10, 2004 09:32 PM
edtxag
Jul 31, 2004 09:14 PM
Quick Reply: Will EvoScan monitor fuel pressure?
