Need TEPHRA mod info for Aquamist setup on EVO X
Hi all, I need some info on how to set up an Aquamist HFS-1 for an EVO X using an alternate map switching system as the failsafe. Below is a link to a video showing an EVO 8 with the Tephra v5 mod being used with an aquamist setup, and apparently this allows you to run two different, fully tuned boost maps that can be switched back and forth instantaneously by pressing a button on the aquamist guage. http://www.youtube.com/watch?v=dWUNj-s3GBE How does this work? Where are the maps stored? Can the low boost map be set up as a failsafe map that will switch automatically in the event of a system failure, or are they only manually switchable? In any case, I'm not sure if Tephra has even made this "v5" mod for ecuflash for the X yet, but if not, are there any other options? Thanks for the help guys.
your *best* bet is to contact Richard from Aquamist on the Aquamist Forum: www.waterinjection.info
He is very very helpful...
scheides
124
Feb 6, 2014 02:15 PM
chriswolf81
Nov 29, 2013 06:53 PM
EvilTechnology
Feb 28, 2013 05:29 AM
scheides
15
Jan 25, 2008 01:11 PM
