Stopping the fuel trims affecting WOT fueling
Hi All,
Just a quick announcement to say I think I have worked out how to disable the trims affecting WOT fueling.
Thanks to Acamus for some seriously hard core disassembling
Ok we all know how the Fuel Trims work, basically MAFHz bins, so Low/Medium/High
Usually High isn't used, here is why:
Left is stock, Right is my modified one
So the High FT won't be used unless the MAFHz goes above 1593.75, which won't really happen on stock turbo.
So I have modified the High bin so it's lower. And thus gets used.
Now here's the best part, because of how the STFT works, the High FT should really NEVER get populated with anything OTHER than 0%.
I have done a log and you can see the High FT being used in the fueling calculations, and you can also see it being set to 0%, so now I don't have my Cruise (Med) Trim affecting WOT.
That's for 53040010, but also should work for 526800XX - If your values for above don't look very similar to mine then something's wrong.
If your interested in logging trims then find the MUT_TABLE - then you have the addresses you need to log:
MUT0F = STFT
MUT0C = LTFT_Low (Usually Idle)
MUT0D = LTFT_Medium (Usual Cruise)
MUT0E = LTFT_High (Usually not used, but that's what this MOD is all about)
MUT50 = Copy of the trim currently in affect
DISCLAIMER: DO NOT USE THIS UNLESS YOU HAVE A WIDEBAND AND LOG YOUR ECU
Cheers
D.
Code:
<scaling name="LT Trim Hz" units="Hz" toexpr="x*6.25" frexpr="x/6.25" format="%.2f" min="0" max="1593.75" inc="6.25" storagetype="uint8" endian="big"/> <table name="Closed Loop - LT Trim Control" category="Fuel" address="5557f" type="2D" level="2" scaling="LT Trim Hz"> <table name="Conditions" type="Static Y Axis" elements="4"> <data>Low -> Mid</data> <data>Mid -> Low</data> <data>Mid -> High</data> <data>High -> Mid</data> </table> </table>
MUT0F = STFT
Cheers
D.
That's awesome!!!
Thank you for this...
I finally got my cruise trims -1.01 on average to 0. But this will make your life so much easier. I will let you know how it works.
EDIT:
THIS IS HOW IT LOOKS FROM 52680020.ROM from a 2008 GSR.
IS there a need to edit the top two values to what you have posted?
EDIT:
Awesome find!
Are the MAF values really in Hz still? I thought that was indicative of a Karman vortex air meter, which we don't have any more... at least I don't believe. I thought it was a hot wire MAF now, 1-5 V or whatever.
Awesome detective work there Tephra! I'll test these tonight and report back, the difference between blowing unburnt fuel and being relatively clean seems to be somewhere between 11.5 and 12.0 AFR's on my particular car, and the 3-5% LTFT swings from day to day were driving me nuts lately. The car would haul **** and be mostly smoke free, then after it adjusted itself the car wouldn't pull quite as hard and you could visibly see a smokescreen behind with richer AFR's. This will make the car MUCH more consistant!
Can someone recap this for me? My understanding is:
- fueling from day to day (not pull to pull) would vary significantly on evo x's (by how much?)
- the cause was determined to be a varying mid trim
- earlier evos trims would not effect wot but evo x's it does
- tephra and acamus figure out a way to change the cut point from mid-high
- therefore you are in high trim mode during wot, and thus wot is not effected by the mid trim
- the high trim is always 0% (why?)
yes there is a IX equiv, the XML is actually stolen from the CT9A forum, just the address is different.
crcain:
As I tried to explain when in closed loop the STFT drops to 0% (or 100% depending on your logger)
Since the LTFT are just averages of the STFT for various MAFHz bins it is logical that when STFT is 0% then the LTFT average will be 0% as well.
crcain:
Another issue was that at higher airflows, if I was currently at +5 LTFT and it surpassed that higher hz reading at 6000-6500 rpm's with a larger turbo, out of the blue the 11.5 AFR that I tuned for might lean out to 12.0 AFR unexpectedly when it changed from mid to high trims.
Like Tehpra said, the high trims that we are kicking in earlier now are going to average 0% since the running average of the STFT during WOT should always be 0%. I love this!
You should be able to see the trim being used by logging MUT50 - same formula as the other trims...
You can log MAFHz with MUT1A (x*6.25) and then you should be able to see when the STFT drops to 0% (closed loop)
