boost question about evo 10
Old Dec 20, 2009 | 07:32 AM
evokenny's Avatar
im just now coming back to the forums. I used to own an fully built evo 8 and sold it not to long ago. I was thinking about picking up a evo 10 and I was wondering whats the boost capabilities of the evo 10 , how much psi can I safely run under stock internals, without upgrading the rods, pistons, or block? and how much power can the evo 10 gsrs hold under stock internals?
Old Dec 20, 2009 | 09:15 AM
chriswolf81's Avatar
I think most people run 24-27 psi on pump gas and 30+ on E-85.
I think I saw some vendors get to 700HP. Stock internals can hold that power, but for how long???
I think people who strive for that kind of power do not DD their car, so they are more likely to rebuild motor to sustain that power on the track.
But I am sure this will change with more time. Learning more about the 4B11
Old Dec 20, 2009 | 02:02 PM
mlomker's Avatar
Quite a few threads on this. Most are doing rod bolts & head studs on cars that cross into the 400's on a low reading dyno.
The 600+hp motors haven't had much longevity to date. Ryan Gates is running 500-something on his car using a beta version of the AMS turbo. The rule of thumb for the 8 & 9 owners (that I've talked to) is also right around 500, so it seems that the 4b11t is in the same ballpark.
The stock-sized turbos (and simple fueling systems, for that matter) max out in the low to mid-400's so that's where most people have stopped.
Old Dec 21, 2009 | 07:25 AM
Gump's Avatar
My daily driving setup was 27psi on a 35r.
Old Dec 21, 2009 | 06:12 PM
evokenny's Avatar
how many psi does the stock turbo run , and how much can it max out at?
Old Dec 26, 2009 | 06:16 AM
darthvader's Avatar
I think you can run 400whp on stock block no problems sfter that the clock is ticking
ADVAN_EVO
Lancer Aftermarket Forced Induction Tech
Mar 31, 2013 10:23 PM
INJEN///
Sep 24, 2010 12:23 AM
jacfumo
Lancer Engine Tech
19
Dec 10, 2008 03:08 PM
zedevo
12
Oct 26, 2008 08:14 PM
APEX1
16
Sep 29, 2007 03:41 PM
