Some GTR Goodness in the EvoScan GPS
If you had a computer, you'd be using the desktop version of EvoScan, and there are many gauge layout available for that version. Not to mention, you can make your own too. This discussion only pertains to the EvoScan GPS unit.
Silver Sponsor
hey dude, just add me to msn messenger hamish@hotmail.com I can give you a walkthrough. you should be able to work it out by opening the template2.txt file in the latest EvoScanPPC 2.0 version. I will do a walkthrough howto soon.
@EvoRS06
make sure you're using the latest 2.0 version that was released a couple of days back. PM me if you need help.
Hamish, the NumericGauge - ShowPeak - Min doesn't work right. It changes color from Red to Blue, but still shows the Maximum Value.
Not a big rush for it, because it doesn't really matter. I set up a display with my Mivec timing, and because Exhaust runs negative, it needs to show a Min instead of Max.
Oh, while I have you, I have tons of address definitions for the 2010 X (and probably RA), if you want them for future updates. I have the full list posted on the other forum, but I can email them to you or whatever you want.
Golden, you da man! Can you post the new addresses as a ticket on evoscan's website. That way Hamish would have something to go by. Thanks mate.
Silver Sponsor
http://www.evoscan.com/gpsnav
UPDATED: 22nd June 2010 EvoscanPPC.exe v2.1
• This is a FULL copy of the EvoScanPPC folder.. backup or rename your existing EvoScanPPC folder on the SD Card first
• Files updated:
\EvoScanPPC\EvoScanPPC.exe
• Fixes ValueFontSize bug for NumericGauge.
• now includes GaugeTemplate version checking. i.e. Minimum EvoScanPPC Version, v2.1
• BarGauge Images now supports BarGaugeDirections Left, Right, Up, Down. Includes working Peak Bar line.
\EvoScanPPC\DataSettings\Data.xml (made load faster by removing notes fields)
\EvoScanPPC\GaugeTemplates\Template2.txt (sample for new bargauge directions)
• Files updated:
