Unable To Access Tables In My ROM (52680022)
EvoM Community Team
This is about to start popping up alot.
This rom (22) is a brand new flash, so the release of ecuflash does not have tables defined for it.
Just copy any of the other 16-20 hex files, change the file name and identification in the file from the one you picked to 22. It should have a include statment for 15, and next time you open ecuflash all tables should appear.
Thank you for the response. I'm new to this and don't want to make a mistake. Could you go a little more step by step for me please?
Is the goal to make a new file type recognition within ECU Flash or to modify the hex files in the 52680022 ROM to be readable by the current ECU Flash coverage?
I don't really want to change the 5680022 ROM just yet. I'd like to see what Mitsu set in the tables before messing with what is a pretty good ROM. Some claiming it is equivalent to previous "stage one" tunes. I know I noticed a big difference after this latest update.
find 52680020.xml in your rommetadata foler
make a copy named 52680022.xml
open the newly made 52680022.xml and replace all instances of "52680020" with "52680022". I don't believe there are any differing table locations in this rom.
