Just Installed Kelford 214B and...
Just had some Kelford 214B installed, made over 400 whp, they advised me they had an ACS light go off and I knew this was because of the 30psi spike. I picked the car up on Saturday. The only person in the shop was a tech to hand me the keys, rest of shop was off due to weekend. I took it out and it felt great!!....right up untill I pulled out on the freeway and hit the throttle, all of a sudden my boost when from 28 to max out at 15 psi...I was like what the *&^%!!! Nobody is back in the shop untill monday, and I was trying to figure some things out. The first thing that comes to mind is some sort of boost leak, it wont hold more then 15 psi, I have an upgraded Forced Performance actuator, FP Red, halman mbc.
Some it comes down to this: New cams, and it wont hold boost more the 15 psi. I can hear the forced air being pushed out from what sounds like the trubo area. Any help or advice would be great.
wow...you think I would'nt pop the hood before making a post and checking out myself, and then you post something about it?? fail on your part buddy. I went as far as checking all 5 bolts on the downpipe, the exhaust mainifold, the turbo inlet housing, lower icp, cold air intake piping, and missed it by a 1 mm gap in the intercooler. THAT is why I posted, and it worked. So where is the fail??
why do people talk **** to each other when somebody is asking for advice??? Im sick of the negativity. This is a forum to help people not to bash them. Go on a sti, st4, or honda forum and talk ****!!!
