Is my ECU going bad?
Hey guys!I got a problem and hope someone has an answer or some advice. I'm pretty new so anything you say I will greatly appreciate.
Been tuning my X with a reputable tuner via etune and my car has been doing some strange things while flashing. I turned on my ignition switch to the on position and tried to install the new rom but got an error half way. Not knowing what else to do I turned the ignition off and on and loaded the new rom again and successfully loaded but the fans stayed on.
Hit the Exit ECU program state and it supposedly was successful but fans still stayed on. Tried cranking the car but would not start. After a few mins of messing with it and I did turn the car off and on 2-3 times and hit the exit program once more and this time my fans shut off!...
Everything seems to be working fine now but this is the 2nd time its done this while loading a rom. Is my ECU Bricked?
Going to have a busy week I guess. Going to send in my ECU to be Benched Flashed and while they check that I will be checking on my wiring harness. Praying its something simple.
ries
Jun 7, 2006 04:00 PM
