Wire tuck codes p0010 and p0013
Old Sep 27, 2018, 06:24 AM
Normanruben's Avatar
Hello all,
After tackling the wire tuck I am getting codes p0010 and p0013 which loooks to be the camshaft position sensor. I freaked out thinking it was because I had extended the rear passenger sensor wire so I put everything back the way it was but I am still getting those codes. Please help, any input is appreciated. My AFRs are all over the place and I have put off driving the car until this gets sorted out. Could it be a blown fuse, if so, which one? Thanks.
Old Sep 27, 2018, 05:57 PM
ttt
Old Sep 29, 2018, 12:01 AM
Bump
Old Sep 30, 2018, 06:06 AM
ttt
Old Oct 1, 2018, 05:16 PM
Anybody?
Old Oct 1, 2018, 06:39 PM
OHM_Racer's Avatar
is the tiny ring terminal ground around the CPS still there?
Old Oct 1, 2018, 07:56 PM
The plug that gets extended goes to the mivec oil feeder control valve: https://stmtuned.com/products/oem-mi...=2020985307145
CPS did not get touched. Weird thing is that p0013 and p0010 popped up. I am at a loss.
Old Oct 2, 2018, 02:14 PM
OHM_Racer's Avatar
All you did is extend the Mivec solenoid connector wiring? willing to help but you need to be a little more specific to be able to help you.
