-   Evo X Engine Management / Tuning Forums (https://www.evolutionm.net/forums/evo-x-engine-management-tuning-forums-257/)
-   -   (PICS) KNOCK when your LTFT's lean out...check it out (https://www.evolutionm.net/forums/evo-x-engine-management-tuning-forums/452536-pics-knock-when-your-ltfts-lean-out-check-out.html)
Clipse3GT Oct 13, 2009 08:17 PM
If you want to see knock here it is...once I had this knock happen feels like the car falls on it face or you are getting major clutch slippage. However look at the AFR from the AEM UEGO. CBRD is fixing my maps, not sure why this is happening.
Just want to show what real knock looks like... people start yelling wolf when they get 1-2 counts. Try 33-36 knock. Once you start getting 50-70 you are having serious problems.
Lean but no knock...
http://img.photobucket.com/albums/v3...rdGearPull.jpg
Lean knock....
http://img.photobucket.com/albums/v3...6andAFR13s.jpg
Lean still knock...
http://img.photobucket.com/albums/v3...3andAFR13s.jpg
nothere Oct 13, 2009 08:20 PM
can you add load or boost psi so we can see when it happens relative to load?
Clipse3GT Oct 13, 2009 08:24 PM
That I cannot. I am tuned via COBB AP. So I can only show you what happens up to 125KPA which about 19PSI. I can't have MODE23 enabled to show you the other options.
However, hollywood_x suggest it might be signs of the stock clutch slipping.
nothere Oct 13, 2009 08:29 PM
19 psi answers my question,
does this happen on a hot motor or early in the drive?
13 is a little lean for 19 psi , no?
GST Motorsports Oct 13, 2009 08:38 PM
36 is max knock count. At least it was with Evo 8/9.
13.7 AFR is a bit extreme for -6 fuel trim. Have you checked you relay? Is this WOT?
- Bryan
tephra Oct 13, 2009 08:39 PM
36 is max knocksum :)
also as long as your LTFT's arn't maxed out then you arn't really running lean - since the STFT+LTFT will ensure you run stoich
Clipse3GT Oct 13, 2009 08:43 PM
Hmmm....so this could possibly be a slipping clutch that causes this...
GST Motorsports Oct 13, 2009 08:44 PM
You would see a slipping clutch in the RPM log. It wouldn't be a linear progression but shoot up then down and catch.
If it was a real 30+ knock count you would hear it, and possibly see a rod in your rearview...
newcomer81 Oct 13, 2009 08:48 PM
logging rpm & speed could help identify slippage if you can get a high resolution
Clipse3GT Oct 13, 2009 08:54 PM
No rod through the side... car runs fine. :confused: Just felt like the car dropped on it's face. Kind of felt like a slipping clutch... :o
GST Motorsports Oct 13, 2009 08:56 PM
Well I would imagine the timing being pulled from the ECU thinking there is 36 knock counts would be substantial enough to make the car feel like it's falling on it's face. take a look at the timing log ;)
Clipse3GT Oct 13, 2009 09:02 PM
Here is the log from this run...
http://www.mediafire.com/file/wmznzv...3_19.16.58.csv
GST Motorsports Oct 13, 2009 09:10 PM
Originally Posted by Clipse3GT (Post 7609454)
Yup it went from 28* to -7* back to 40* with 33 knock counts. 4000 rpm, 50% TPS.
That would make the car fall on it's face.
Clipse3GT Oct 13, 2009 09:14 PM
So is that clutch slipping or the car running lean??? :confused: :eek:
GST Motorsports Oct 13, 2009 09:16 PM
See post #8 ;)
