-   Evo X Engine Management / Tuning Forums (https://www.evolutionm.net/forums/evo-x-engine-management-tuning-forums-257/)
-   -   DW 1000cc's injector scaling needed (https://www.evolutionm.net/forums/evo-x-engine-management-tuning-forums/458051-dw-1000ccs-injector-scaling-needed.html)
criptballer Nov 11, 2009 05:12 PM
i'm getting my DW 1000 on friday and switching over to e85 and i'm trying to find out if anyone has their latency maps they can post. Thanks guys{thumbup}
delkat Nov 11, 2009 09:42 PM
Scaling
Pump: 713
E85: 562
Latency
6.120
4.200
2.808
1.992
1.488
1.200
0.912
Hiboost Nov 12, 2009 05:53 AM
Are those first two latency numbers super important? I wasn't sure if those lower voltages had much of an impact or not or if it was mainly the 12 and 14.5 volt rows that had the most impact?
delkat Nov 12, 2009 09:34 AM
I'm not sure.
goofygrin Nov 12, 2009 09:58 AM
https://www.evolutionm.net/forums/ev...highlight=1000
search would have returned your answer for you (I searched for "1000" in this forum to find this post, it had almost the same title as yours).
criptballer Nov 12, 2009 02:45 PM
does anyone know why the scaling of e85 is lower than that of pump? i though the higher the number in scaling the more % of the injectors you use. right....? so if we need 30% e85 wouldn't that mean the scaling number would have to be higher that that of gasoline?
GST Motorsports Nov 12, 2009 05:25 PM
For scaling, smaller the number, more da' fuel. ;)
For latency, higher the number, more da' fuel. ;)
- Bryan
Malaxa Jan 1, 2013 06:23 AM
DW 1000 injectors gave you satisfaction?
You could set them perfectly that AFR to be perfect?
Do not you want to share your experience? :)
