Motec 800 plug 'n play evo x
Hi guys do somebody knows about the m800 plug 'n play for the evo x did some body
tried it, i want to know about its price and also what the power it makes if i run gt35r on my x because i got alot of problems with the stock ecu. I hope somebody help me with it also i knew that that the AMS TA/X tuned using motec. |
What's wrong with emarati people and motec!!! haha :D
I know a friend of mine on our website, he uses motec 800 I guess and gt35r.. here's a link to his car: http://www.garage76.com/garage/group...id=10&v=photos ps: you'll have to register first, shouldn't take more than 2 mins |
its in our blood maan... :p
what problems do you have with the stock ECU?
I got alot of problems like limp mode,the car idles alot after i push it hard,sometimes when i push the car it shut off alone,also when we were tuning we saw that the airflow in the screen was 0 doesn't change at all,while everything was ok, so am having hard time with the stock ecu.
Originally Posted by UAE_EVOX
(Post 8019883)
- Bryan |
as far as i know motec pnp only works with GSR's and it has to be tweaked cos it's meant for RS models. yeah the stock ecu does a fine job !
what limp mode do you get?
what DTC is thrown? fix one thing at a time... |
(Post 8019808)
yeah 1 at a time . . .
AMS is doing 700+++ whp with just a stock ecu |
@UAE_EVOX
Are you sure you want to give up things like A/C, S-AWC, etc... and go with a standalone? If it were me I'd try to get one of the reputable Evo tuners to come take a crack at it (e.g. HBSpeed, GST...) I know Jon@HBSpeed was talking about making a trip out here (he's in CA) if there were customers (I'm in for sure.) I'd sooner spend $1000 to fly him out here, then go with a standalone that deletes a lot of features that make our cars fun/livable/safe on the street and track.
Originally Posted by GST Motorsports
(Post 8019910)
All problems with solutions on the stock ECU. ;)
- Bryan |
Hell, shipping it somewhere could be an option as well...
https://www.evolutionm.net/forums/ev...stock-ecu.html |
No offense, I would have to say it's most likely your tuner. There are guys out there making crazy numbers with the stock ecu. It can be done.
Peak numbers are not everything. The stock ECU cant be mentioned a same level with a MOTEC.
ANd also the MOTEC has a ACD ECU too if you really want to go all out :) Also yes they have plug and play ECO from motec but on stock car or low level modifications it is pointless. Only is worth the money if you do a major changes on the engine. |
depends on your purpose.
but for a street car, MOTEC is a waste of time and money :) |
