Some GTR Goodness in the EvoScan GPS
5 Attachment(s)
Mods, can we start a sticky for all layouts and corresponding settings?
Was feeling bored and decided to do the GTR layout for the GPS on RogEvo25's request. Sorry for the piss poor quality. I want to add the remaining gauges for functionality and then release the settings. currently last gauge on first line and last 2 gauges on second line are not working/assigned. http://www.youtube.com/watch?v=jKF5_k9z_lo http://i572.photobucket.com/albums/s...X/IMG_0915.jpg http://i572.photobucket.com/albums/s...X/IMG_0914.jpg http://i572.photobucket.com/albums/s...X/GTRSkin2.png My mad MS Paint skillzzzzzz :lol: MS PAINT FTW !!!!! Here are the attachments: The Alarms.txt and EvoScan.txt need to be renamed to ".xml" files. The bus_horn.txt file needs to be renamed to a .wav file for the alarm to work. |
nice...
pretty cool..
1 Attachment(s)
Interesting timing... check out the one I'm working on... spent 1 evening on it so far.. its come along nicely..
very nice indeed. link it for download would be even nicer lol.
yay +1 for DL nice gauge
Great keep us updated.Any download link? {thumbup}
Originally Posted by evoscan
(Post 8301750)
That's what I started with, I eventually ended up with what I posted. |
Originally Posted by vboy425
(Post 8301773)
Originally Posted by boy36
(Post 8301780)
I can put it up for download as is, takes about 2 minutes, but I want to assign the remaining gauges to proper log items too and then set it up for other to download. I know I haven't been doing anything for our SST friends, but honestly, it won't be too different. |
I'm looking for more inputs on what we can log with the remaining gauges.
The last gauge in the first line is reserved for Oil Pressure, I do not know if we can log that from the ECU using EvoScan. The last 2 gauges in the second line are completely up for grabs though. I can also include numeric fields like the Knock in the posted picture. I'm thinking 1) Timing advance 2) LTFT 3) LOAD .... what else??? :confused: |
I don't think EvoX have has any oil pressure sensor installed in the engine bay?
top 3 gauge --- AFR, Boost, Knock
bottom 3 --- SST temp, Load, Timing adv i'll call it a day ! yay .... thx in advance :) |
yeah, I don't know if there is a sensor for oil pressure in the X, just kept the gauge since most people want it and because I know you will figure out a way to read this too {thumbup}
Originally Posted by E6-X
(Post 8305508)
bottom 3 --- SST temp, Load, Timing adv i'll call it a day ! yay .... thx in advance :) I have decided to use Gauge 2 in line 2 for speed to failitate for those that run tires with different circumferences compared to the stock setup. Currently, you'll need to make a change to the EVAL portion of the "Speed" element in the data.xml file. I tested this last night with my 265 35 18 RE11's and it works well. The speed shown in the gauge is now the same as the one shown in my Garmin GPS. The stock speedo thinks I am going faster. only one more gauge to go (line 2 gauge 3). The SST guys might want to use this for the SST temp, I agree, but what about the GSR owners? Timing adv and knock have already been implemented as numeric gauges. So we need something else. |
/subscribed
+1 for SST temp ;). So in order to get this to show on my AUX of my Kenwood DNX-8120, I'd just need a small computer built into the car and plugged into the Kenwood right? (The computer would be running EvoScan)? |
