OT - Valve lifter
Hi all,
can anyone advice e-shop where I could get stock valve lifters for 4B11 engine? Thanks! |
4B11's don't have lifters. They are bucket on spring, and you need to know the gap between the valve stem and the cam, because the buckets also serve as shims for setting lash.
There are 47 different part numbers of buckets. |
Originally Posted by kozmic27
(Post 8808131)
When you order your buckets, make sure you subtract the lash spec from the thickness you order. I'm sure you thought of that since you already have the gap dimension, but I just thought I'd throw that out there.
MAPerformance has a decent OEM mitsubishi parts connection.
There is also http://www.mitsubishiparts.net/ |
(Post 8809139)
There is also http://www.mitsubishiparts.net/ Martin |
