-   Evo X Engine Management / Tuning Forums (https://www.evolutionm.net/forums/evo-x-engine-management-tuning-forums-257/)
-   -   Can't pull rom on X after unmarrying AP? (https://www.evolutionm.net/forums/evo-x-engine-management-tuning-forums/543981-cant-pull-rom-x-after-unmarrying-ap.html)
blackevolution8 Mar 9, 2011 04:41 AM
Ive never pulled a X rom before. Yesterday I have a customer show up at my work with his car. I asked to pull his stock rom so I can look it over and work on a base map for his new fp red he's getting soon. We unmarry the AP, I hook up my 2.0 cable and try to pull the rom. I get an error every time.
Just to verify what im doing and what I have. Tactrix 2.0 cable, Ecuflash 1.42.2595. I plugged just the box into the obd2 connector. I have the cable used on the 8s and 9s that is required to flash the ecu but I dont see this on the X so its left hanging off the side. I decide to open up my evoscan and see if I can at least start logging at idle and nothing.
Am I missing something for the X's? Definition files I might not have? Is the AP causing the issue even though its unmarried? This is the first car, both subies and evo's, that Ive been unable to pull a rom. Any help would be much appreicated!!
tephra Mar 9, 2011 05:02 AM
Well you dont need the extra plug for EvoX. So dont even bother to connect it.
Copy/paste the EcuFlash log window in here - so we can see...
blackevolution8 Mar 9, 2011 05:11 AM
I figured it wasnt used on the CAN system. I couldnt see a plug for it either.
Unfortunetally I didnt save a copy of the screen and I wont have my hands on the car for a few days. Ill try another attempt at that time and save the screen.
Golden Mar 9, 2011 07:16 AM
Did he marry up the AP again without issue?
If so, then something must have been wrong with your setup. Have you read an X before?
blackevolution8 Mar 9, 2011 07:16 PM
Yes as soon as we married the AP it fired right up no problems. I had a problem trying to pull a rom from an 2 '05 Foresters today too but as soon as I got home I worked on my evo 8 tune with no issue. That was the first X ive tried pulling a ROM from. Im thinking I need to uninstall and reinstall ecuflash.
tephra Mar 9, 2011 07:32 PM
before you do that - grab the log window and copy/paste it here...
blackevolution8 Mar 16, 2011 08:07 PM
So I finally got a chance to try to pull the rom on another X. This is the error I get. I also recently tried pulling roms off two 05 turbo Foresters and It doesnt even try to pull the rom. It just flashes error. I didnt get a copy of that screen though. Im able to pull roms from 02-03 subies and my evo 8 no problem. My boss has no issues with his laptop and we have the same versions of ecuflash and tactrix 2.0 cables.
http://i338.photobucket.com/albums/n.../romnopull.jpg
tephra Mar 16, 2011 08:17 PM
are you choosing CAN based Mitsubishi when you do the read?
blackevolution8 Mar 16, 2011 08:19 PM
Yep I sure am.
tephra Mar 16, 2011 08:21 PM
I would uninstall, delete the ecuflash directory, then reinstall...
blackevolution8 Mar 16, 2011 08:29 PM
After having issues with the foresters, I uninstalled and reinstalled ecuflash, but perhaps I didnt get everything deleted? Just one year ago I did a reformat to my laptop but I never tried pulling evo x roms before that.
