Any Evo x MR's tuned on E85?!?
I'm thinking about going corn fed! I just wanna to get some feedback on MR owners that are tuned for e85. The good? The bad? Is it a PITA? Any feedback would help.
Is there no one out there? I'm considering the switch myself and would also like some insight.
We've done a bunch.
Yes mike you have mentioned that. I wanted to get some perspective from other MR owners that got tuned on E85. The good, the bad and the ugly.
It's a fairly common swap, Cobb even has AP OTS maps for it.
yep
be careful of TQ cause without a proper tune ittl eat clutches |
Originally Posted by MikeB@FFTEC
(Post 9343937)
We've done a bunch.
To the OP: With proper tuning, it's just like running E85 on a GSR. I highly recommend E85 if you have it available. I have both my Mitsus on E85 and it's great fuel. You do want proper tuning to keep the clutches and torque management of the SST happy. Not everyone can do this. In the bay area there was only one person currently who could. |
Cobb did my e85 map; I couldn't be happier with the performance. Finding e85 can sometimes be a challenge, so take that into consideration.
http://accessecu.com/dyno/graph.php?...rgb1=000000255 |
Originally Posted by mrMTB
(Post 9346521)
mrMTB has the stock clutches along with a stock airbox and [modified] stock catback. He also has the AMS downpipe + HFC.
Originally Posted by Kracka
(Post 9346615)
I'd imagine injectors and fuel pump. |
^^ are the stOck clutches are holding up pretty well with 390+lbs of torque?!?
Nice lookkin e85 numbers on that MR.
I'm guessing upraged injectors of atleast 1000cc and a 255lph fuel pump for the fuel swap. |
Stock clutches are handling it perfectly well. The mods for that were:
AccessPort DW 800cc injectors Blaqops Fuel Pump kit w/ Walboro 255lph pump Grimspeed EBC K&N Drop-In Filter AMS O2 downpipe AMS 200 cell cat Modified stock cat-back I do have the SSP shallow SST pan and front-mount cooler kit, but I only turn that on when I'm at the track. For the minimal amount of modifications, I certainly could not be happier with the performance. |
Cobb Plano put my MR on e85 today.
| All times are GMT -7. The time now is 05:19 AM. |
