ltft's
hey guys, i've been looking at my logs and noticed all my ltft's are always negative. usually ranging from -3 to -7 and at some times it reaches -9. highest it's gotten is 0. is this horrible for my car?
Nope. It's just outside the norm of +/- 5%.
probably just needs a little extra MAF scaling lovin'
Originally Posted by Golden
(Post 9335652)
Well when at 5psi or greater boost the AFR's depend more on how it was tuned.
For closed loop where the O2 sensor is trying to keep the AFR's around 14.7 the LTFT's will adjust up and down based on what it learns. If it's hovering between -3 and -7 that actually means it's trying to REMOVE 3%-7% fuel on average to reach the 14.7 AFR's during cruise. It's still within the ECU's adjustment range so not horrible but it might remove a bit more fuel than expected as the turbo is spooling depending on where your Hz crossover is set. Has anyone tuned you car? |
Originally Posted by Hiboost
(Post 9336535)
| All times are GMT -7. The time now is 06:09 AM. |
