Logging SST useful parameters
So I worked these out about a year ago - but due to the "sensitive" nature of SST "tuning" I decided to only give them to a few select peeps.
Anyway's the time has come that they become public, you MUST have EvoScan 2.8.0005 or above: Code:
<DataListItem DataLog="N" Color="" Display="SST Transmission Temp" LogReference="SST_TM_Temp" RequestID="CAN28-0" Eval="x-50" Unit="Deg F" MetricEval="x-50" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="0" GaugeMax="1000" ChartMin="0" ChartMax="1000" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> Cheers D. |
Very nice, thanks.
woot woot thanks tephra, u da man!
Waits for the thread entitled "I have Tephra's new SST logging software and NOW my box slips like a MOFO" to pop up.
Originally Posted by kijima
(Post 9599343)
Thank you, I copy and pasted this into my xml under Ralliart section and when i go to Logging tab- Edit Data Item List, im getting the error "The given key was not present in the dictionary". Can someone tell me how to fix this?
I just added them in manually. Guess I like repetitive data entry - it's kind of soothing for my overworked/underpowered brain...
Zip and post your XML. Probably just a typo. And yeah, it's amazing how my clutches DID start to slip as soon as I began logging this! ;) People will be howling out for better SST clutch pressure management... :lol: Rich |
yeah it was depressing when i thought my SST was working great and i tried these out.
However, i did get things to improve a little... it's still there though :( |
Well I am digging through the ECU's throttle/torque/SST code right now..
I had some dyno time with and SST yesterday and I learned a lot, but I have another session on Thursday. So hopefully I will have this all figured out soon... |
^ good luck sir.
because I'm going to have a lot more torque soon, and i want to be able to use the throttle in judicious amounts :) |
Good work mate!
Originally Posted by tephra
(Post 9599903)
Lol i appologize for my ignorance on the subject but what does this do?
You can see line pressure acting on each of the two clutches
And you can watch your clutches slipping in real time as you pile n the torque... keep an eye out around 5500rpm ;) |
*yawn* this is soooo last spring...... LOL
