-   Evo X Engine Management / Tuning Forums (https://www.evolutionm.net/forums/evo-x-engine-management-tuning-forums-257/)
-   -   New to tuning think I'm figuring it out (https://www.evolutionm.net/forums/evo-x-engine-management-tuning-forums/755930-new-tuning-think-im-figuring-out.html)
Tbiggybig191 Sep 10, 2019 03:02 PM
2 Attachment(s)
So I recently just started tuning my over built evo x all the local tuners gave up on the car saying its proving difficult takes to much time etc w.e excuse they can throw at it either way I'd like to start a thread on my progress and maybe get some feed back on my map so far I'm tuning through ecuflash with tephra mod and so far I got it to idle and run and drive and get 10 psi I just converted the table to 4 bar so that light have solved the only being able to do 10psi I think I have my injectors properly scaled but I've done absolutely nothing to compensate for my cams so idle is smooth but it hints for fuel pretty bad jumping from 14.5-16.7 afr just sitting I raised my rpm some pretty much through the rev range the fuel is stable but has this same trim of bouncing one or 2 points I'll post a link to my build and a copy of my basemap if anyone wants to take a look thanks guys critique away I'm completely new to tuning so every bit good bad helps
Cheers!
https://www.evolutionm.net/forums/evom-newbie-faqs-forum/755921-long-time-lurker-first-time-poster.html#post11885882
W4r3z Sep 16, 2019 08:21 PM
Hey,
XML File for your rom will be needed + A log of your car if anyone is to be looking at it !
Tbiggybig191 Sep 20, 2019 07:58 PM
Originally Posted by W4r3z (Post 11886561)
Hey,
I posted the xml and since then ive just bumped up my mivec tables for the cams my ecu was recently bricked by a tuner who came by and was going to help me clean up my map got 20mins in and he bricked it ive been trying to bench it for the past 2 weeks 😭 i also tried to set up to datalog through rear o2 sensor but cant seem to get it to log properly so my logs dont have afr
