Whistling noise on idle
Old Apr 12, 2009 | 01:25 AM
EndlessRed's Avatar
i've been hearing this noise ever since i purchased the car - whenever the car is idle, i can hear this constant whistling/buzzing sort of noise. like "beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep" but without the p and it's constant. i believe it's there as i drive too, but the engine noise would drown it out. at first i simply took it as part of the car's operation, but now i'm wondering. it's still there after i swapped UICP/LICP/FMIC, so i don't believe it's a boost leak. and it also seems like i'm holding boost just fine. anyone else know what i'm talking about?
Old Apr 12, 2009 | 02:08 AM
MOB EVO X's Avatar
I know exactly what your talking about. I've had the same thing since day one. Idk what it is. but I think maybe its the turbo spinning and makes that noise.
Old Apr 12, 2009 | 02:15 AM
mrbkkt1's Avatar
either of you have an aftermarket BOV? it could be that, if it's not tuned/ sealed properly.
Old Apr 12, 2009 | 12:13 PM
EndlessRed's Avatar
no...like i said, it has that noise since day one, and i got the car brand new from the dealership.
Old Apr 12, 2009 | 12:16 PM
EndlessRed's Avatar
that's a good guess - the noise would lower if the rpms drop below idle...maybe i'll need to sit in other evos and see if they have the same noise.
Old May 12, 2009 | 03:47 AM
rageagtm's Avatar
i think its fuel pump, mine makes it too.. only hear it at idle with audio and low noise around.
Old May 12, 2009 | 09:56 AM
Mtandre21's Avatar
Now Im wondering bout mine...Im gonna go check
Old May 17, 2009 | 07:24 PM
EndlessRed's Avatar
good call - i was working on the cat-back on a lift, and when i was checking for exhaust leaks, i hear the whistling, and it was very loud under the car. turns out it was the fuel pump.
not like it matters now because with my exhaust i can't even hear it
rotterdam
Outlander Sport
16
Jan 11, 2020 12:50 PM
smevox
Jan 14, 2019 07:13 AM
Charlie-Y
Mitsubishi TC-SST Discussion
Oct 19, 2016 09:04 AM
AndyBandy
Mar 1, 2006 04:52 PM
masterevo
10
Apr 23, 2004 06:17 PM
