02 sensor
02 sensor
looking for 02 sensor.... i have seen some people having the problem of stripping the bolt on an 02 sensor, it happened to me, but i want to know if there is another way of replacing it other than buying from the dealer and paying $325? any suggestions??
..if you get the new 02 sensor..
before you install it.. get a tap and "clean up" the threads in the 02 bung.
coat the threads of the new sensor with a little anti-sieze before you put it in.....
.....that way , if you need to remove it again ,
it will come out wthout tearing the threads off of the sensor....
...the original problem was , you tore the threads off of the sensore when removing it , due to the threads being siezed in the bung.
