Compression Test Results
Straight from the service manual:
Standard value (at engine speed of 200 r/min): 1,090 kPa (158 psi)
Limit (at engine speed of 200 r/min): Minimum 650 kPa (95 psi)
this engine is simply put it TOAST. when have any of you seen a evo with compression results that low. never. not the old evo's or new. i say ringlands with my experience. time to spend big bcks. bet you wish it was a 4g63
You notice any engine running at 95 psi on each cylinder. A 4B11T would barely run in a condition like that...
Something was definitely wrong with my motor, but the compression showed 150s across the board and the leakdown was perfect.
I would say re-test and see if the results are the same...but 95s can't be good...
Gary@MellonRacing
Oct 30, 2010 03:04 AM
